How does this regulator works?
PAXTON FUEL PRESSURE REGULATOR 3 PORT BYPASS STYLE
Fuel Injector or Carb high volume bypass regulator
This is a new Paxton Products bypass (fuel return) style fuel pressure regulator. It has AN-10 inlet port and 2 AN-8 o-ring style outlet ports with a 1/8" npt port for gauge. It also has a vac-boost reference hose nipple for a turbo or supercharger to raise the pressure 1 to 1 ratio fuel pressure climb.This can be used on a car with big fuel requirments and big pumps. It is rated at 50lbs. inlet pressure max. and has a adjustment from 3-35 psi. Bonus!! This will also come with a high pressure fuel injector pressure spring (35-90 psi) so it can be used with fuel injector systems. This regulator is compatiable with gas or alcohol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">This will also come with a high pressure fuel injector pressure spring (35-90 psi) so it can be used with fuel injector systems.</TD></TR></TABLE>
danno33
Dec 27, 2006 02:16 PM
