Wiring in an Aeromotive fuel pump...need help here
Old Dec 23, 2005 | 01:04 AM
Pandahatch's Avatar
Default Wiring in an Aeromotive fuel pump...need help here
I just installed my fuel cell and have all my plumbing for it done but I need some help with the fuel pump wiring. I'm using an Aeromotive A1000 pump. Aeromotive says to use 10ga. wiring for it but I have no idea what to do here. Should I go all the way to the source of the stock wiring and run 10ga. all the way back or can I do something else with the stock wiring right there? Any help is appreciated here. TIA.
Old Dec 23, 2005 | 03:12 AM
k24em2's Avatar
Default Re: Wiring in an Aeromotive fuel pump...need help here (PandaHatch)
Wire directly from the battery.
Old Dec 23, 2005 | 07:40 AM
gldndrgn14's Avatar
Default Re: Wiring in an Aeromotive fuel pump...need help here (k24em2)
i ran it off the oem plugs. made a male and female adapter to 10 guage of the power and grounded off the pump and the oem wire. so basically 2 grounds. its been running for almost 2 years no problems daily driven. and i put a lot of miles on the car.
Old Dec 23, 2005 | 11:26 AM
Pandahatch's Avatar
Hmmm, I just don't want to cook any wiring or catch my car on fire hahah, using a relay method from the batteryis another option here too...need to find the wiring on it.
Old Dec 23, 2005 | 12:16 PM
2k.civic.si's Avatar
Default Re: (PandaHatch)
run a 10ga wire directly from the positive side of the battery to a relay next to the pump run 10ga from relay to pump....use wire that ran the oem pump to kick the relay...run ground to frame
Old Dec 23, 2005 | 01:47 PM
Pandahatch's Avatar
Sounds easy enough. Thanks for the help!
Old Dec 23, 2005 | 02:50 PM
gldndrgn14's Avatar
forgot, i am running the fuel pump controller now. but i did run it right off the oem wire for about a year and a half. now i have the pump controller straight to the battery and the factory wired to the controller. the controller runs the pump. and all grounds to the chassis.
Old Dec 23, 2005 | 11:17 PM
Pandahatch's Avatar
Got it all wired up tonight and it looks super clean. The only thing I used different is I used a 30amp relay instead of a 40amp, I still used a 30amp circuit breaker and 10ga wire for everything except for the stock fuel pump wire just for the trigger. Think the 30amp relay will be OK?
Old Dec 23, 2005 | 11:32 PM
30amp is fine
jdm_h22
Oct 19, 2012 02:30 PM
Bond
Oct 5, 2009 05:37 PM
BB6-213
Jun 9, 2007 06:47 AM
Pandahatch
Jan 21, 2006 02:47 PM
ImprtTuner88
Oct 8, 2003 04:09 AM
