vafc + fmu =?
do i need a fmu if i got a vafc? i got a ac fuel rail.i know i need a fuel pump,but does that complete the fuel setup im gunna need.im running a stock internal lsvtec at hopfully 8 psi on a rev-hard kit,ohh and i got dsm 450 injecters.....thanks
sincerly,
a noob to boost
sincerly,
a noob to boost
i got a pwo. hondata dont make anything for that tho....and thats all i hear about is hondata.i dont even know if its a chip, or a whole ecu?neptune ,crome,do they make anything for obd0?
you can run either or, but not both. if you wanna go chipped ecu on crome, it'll be somewhat easy. depending whether or not you can tune your own car.
99.8% of the people here will say ditch all that stuff and get a decent e.m.s. if you are staying and staying is the key word low boost, the fmu is fine. a little fat but fine. an fmu and the vafc will melt pistons. it is either one or the other. but, frank, 99lspwr is running pretty good boost with tat setup, but he went into far more detail with it.
your best bet is to get a good strandalone you can grow into. but thats just my o.o2
good luck either way and take care.
