Cam Seal question
Old Dec 22, 2005 | 06:54 PM
4DRmafia's Avatar
Default Cam Seal question
I am gettin ready to replace my cam seal sometimes tomorrow and i was wondering how hard to replace it? Do I have to take off my valve train and my cam shaft at all?
Old Dec 22, 2005 | 07:49 PM
jdmcars.com's Avatar
Default Re: Cam Seal question (SkipMic2006)
Depends on which cam seal you are speaking of (the 2 on the cams @ timing belt side) or the single seal on the other end if DOHC. What engine?
Old Dec 22, 2005 | 08:01 PM
4DRmafia's Avatar
oh sorry it an D16a6 and it oil leaking on the timing belt side
Old Dec 22, 2005 | 08:33 PM
fourthgenhatchB17's Avatar
Default Re: (SkipMic2006)
Cam removal is not needed. You will need to slip the timing belt off the cam gear and remove the cam gear. You might have to remove the rear timing belt cover if there is one....its been awhile since ive worked on A6, lol.
Old Dec 22, 2005 | 08:38 PM
4DRmafia's Avatar
oh alright, i know how to get to there i was just wondering if i had to remove the cam shaft itself to get to it but thanks alot fellas!
Old Dec 22, 2005 | 08:45 PM
Mr.Noodles's Avatar
One trick I learned was to zap strap the timing belt to the cam gear in a couple of places. Then undo the bolt and slide the cam gear off the cam. Once the seal is changed, slide the cam gear with belt attached onto the cam and then remove the zap straps.
If you do this at TDC, just ensure the cam and crank timing marks are aligned to ensure cam timing is unchanged.
Good luck.
EdGe(161)
Apr 11, 2011 09:28 AM
MR Rodgers
Jun 26, 2007 09:46 PM
frankenstienEk
Jan 29, 2007 10:33 PM
EJ8tunerman
Jun 21, 2005 04:35 PM
EK4 hatchback
May 31, 2004 08:45 PM
