hydro tranny in 93 ls with a b16 obd1 swap?
is this possible and what is involved with the swap?Because i know my ls has a cable tranny.....and if i could do this what are the pros of having a hydro tranny?
i tried searching this but didnt get much of anything...
hasport now sells a cable to hydro conversion for our cars. so you can use a hydro transmission with the stock 90-93 teg cable system.
http://hasport.com/catalog/pro...d=128
i was actually thinking of this today at work cuz im thinking of getting a CRX and i want to do a full obd 1 swap and put a hydro tranny in as well. if it were me id just do it like it was an auto to start out with get yerself the clutch master off a new teg retro-fit it on there and make a braided piece of hose for the line. in my mind this should work but i might be wrong ive never done a auto to 5 swap before. GL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 »</TD></TR><TR><TD CLASS="quote">wow thanks that helps a lot projettteg that looks like thats all i will need, a little on the expensive side but it will be worth it
thanks</TD></TR></TABLE>
yea its alittle up there, but hmo is one of the best places to get a swap.
plus getting the vtec tranny on the b16 is alot better then butting the ls one on there.
again at work i was spacing off... can u put the speed sensor out of a cable b-series tranny into a hydro b-series tranny? if not then u dont have a speedo when this is all done. and then i got to thinking even more if u r running obd1 and u dont have a speedo sensor wired in u will throw a code u might want to plan on running crome or uber so u can disable these codes. GL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic »</TD></TR><TR><TD CLASS="quote">again at work i was spacing off... can u put the speed sensor out of a cable b-series tranny into a hydro b-series tranny? if not then u dont have a speedo when this is all done. and then i got to thinking even more if u r running obd1 and u dont have a speedo sensor wired in u will throw a code u might want to plan on running crome or uber so u can disable these codes. GL </TD></TR></TABLE>
yes
yes
yeah projectTeg from one of my other posts i realized thats its going to be slow as ***** but im going to have to keep it on there for a couple opf months to save some cash....this is going to be sweet
DelSols-plural
Sep 21, 2011 07:25 AM
BuBBa y0!
Dec 16, 2003 07:13 PM
