? any mods to swap a b16 in a 92' teg?
Old Dec 22, 2005 | 04:53 PM
mantegra's Avatar
Default ? any mods to swap a b16 in a 92' teg?
i have a 92' teg-gs, would i have to change any wiring if i swap a b16a2. and it might sound dumb, but would i need to change the upper driver side mount, still using the stock b18 cable tranny? thanks.
Old Dec 22, 2005 | 05:03 PM
projectTeG's Avatar
you talking about the 99-00 b16a2 out of the civic si? then yes you have to use a different wiring harness(i believe) because the b16a2 engine is obd2. the whole driver side mount that bolts on the engine(bracket and all) will need to be changed to the 92 bracket and mount because the ek's use driverside jelly mounts.
Old Dec 22, 2005 | 05:15 PM
mantegra's Avatar
Default Re: (projectTeG)
sorry but according to my research the b16a2/a3 is for a ....well 93'-95' del sol, if so then isnt it obd1, or am i way off base i was more into single cams. so im trying to get the right info, u know, any help is appreciated
Old Dec 22, 2005 | 05:23 PM
projectTeG's Avatar
Default Re: (coffeeman1321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coffeeman1321 &raquo;</TD></TR><TR><TD CLASS="quote">sorry but according to my research the b16a2/a3 is for a ....well 93'-95' del sol, if so then isnt it obd1, or am i way off base i was more into single cams. so im trying to get the right info, u know, any help is appreciated</TD></TR></TABLE>
umm...the b16a3 are out of the del sol vtec's(94-97) and the b16a is out of the 99-00 si, and they both are obd2.
Modified by projectTeG at 2:34 AM 12/23/2005
Old Dec 22, 2005 | 05:35 PM
projectTeG's Avatar
Default Re: (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">sol's werent made after 97.
b16a3 is from 94-95 del sol
b16a2 is from 99-00 si
thats from hondaswap.</TD></TR></TABLE>
whoops...sry about that forgot....&lt;&lt;&lt;brain fart.
yea they del sol vtec's were made from 94-97...so 2 of the years were obd1
Old Dec 22, 2005 | 05:42 PM
mantegra's Avatar
ok, so if u dont mind. 1. i need to look for a 94'-95' b16a3?
2. my 92' teg is concedered a DA?
even if u know of a link would be great.
i that u for ur help, ha, im just trying to figure this all out, lol, ya i use to have a 91'hatch dx, so u can guess its all french to me
thank u,
Old Dec 22, 2005 | 05:48 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coffeeman1321 &raquo;</TD></TR><TR><TD CLASS="quote">ok, so if u dont mind. 1. i need to look for a 94'-95' b16a3?
thank u, </TD></TR></TABLE>
if your going to look for a b16a3...just go to this sight and order the b16a swap for the obd1 tegs(third from the top on the jdm-usdm engines section) http://hmotorsonline.com/
yes 90-93 tegs are commonly called DA(chassis code)
but technically
90-93 3-door hatches are DA9
90-93 4 doors are DB1
and 92-93 gsr's are DB2
its 1700 plus shipping and you get the short gear b16 cable tranny, Lsd is 300 more.
hot92honda
May 6, 2007 12:03 AM
vtec25
Dec 6, 2006 04:23 AM
lovnmysol
May 3, 2005 10:36 AM
pdiddy
Dec 9, 2002 06:37 PM
