Fuel Pump not working.
So I tore my intake manifold out to get to one of the bypass hoses, after I was done, I put it all together, and everything seems to be in working order, except now I turn the key to the run posistion and don't hear the usual two second "hum" off the pump.
So...Where do I start looking for the problem? I'm fairly sure that all the wiring connectors are in the right place. But anything specific that I could have f*cked up working with the IM/Throttle body?
Thanks.
Modified by Jeffrey9 at 5:24 AM 12/22/2005
Thanks.
Yeah, check the reley and also check to make sure if you do/don't have fuel pressure...maybe it's just being quieter than usual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Yeah, check the reley and also check to make sure if you do/don't have fuel pressure...maybe it's just being quieter than usual.</TD></TR></TABLE>
Yeah - because to tell you the truth, i never listen for mine to come on - i don't even think i've heard mine before on my lude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin »</TD></TR><TR><TD CLASS="quote">
Yeah - because to tell you the truth, i never listen for mine to come on - i don't even think i've heard mine before on my lude. </TD></TR></TABLE>
Well that's what I'm worried about. My car is on a 250 lb. Diet. And obviously this includes the back seats, etc. I can hear the fuel pump when it's working plain as day.
Also, how would I go about checking the relay? I know where it is, but how do I test it?
Well if it had fuel pressure I imagine the car would start.
Modified by Jeffrey9 at 3:17 PM 12/22/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeffrey9 »</TD></TR><TR><TD CLASS="quote">N00b question. Where exactly are the grounds for the Thermostat housing and the TB that you guys are speaking of?</TD></TR></TABLE>
Right below where the longer radiator hose connects to the intake manifold....and there's not one on the TB.
JdmKid187
Nov 13, 2004 01:55 AM
