simptoms to a bad tranny etc.....
when my car was rowling or just going on the highway i was hearing a noice like my wheel bearing were gone changed them still hear the sane noice then i rebalanced my tires and rotated them even though it helped on some vibration i had i still had the same noice i know my left axle is no good so i just ordered two brand new axles from (Raxles.com MARTY nice guy) see what happens....
also have a little car hop on first and second gear but it only does it when the car is cold not sure why is that thinking my tranny bearings are gone not sure any feed back would be greatly appreciated Thanks
Modified by BlUeHoOdCiViC99 at 5:44 PM 12/21/2005
Modified by BlUeHoOdCiViC99 at 7:40 PM 12/21/2005
you need to fix the axle problem before you can diagnose the tranny problem. but you most likely went low on tranny fluid and damaged one of the bearings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therealpoorboy »</TD></TR><TR><TD CLASS="quote">you need to fix the axle problem before you can diagnose the tranny problem. but you most likely went low on tranny fluid and damaged one of the bearings.</TD></TR></TABLE>
If it's a vibration, it could be your axles.
I had an experience where I was at the track, and shifted from 1-2nd a little too rough and heard a bang, then from there, the car would vibrate at high speeds (usually from 65+mph)
I was not sure what it was, and was playing with a lot of fixes, mounts, traction bar, etc.
In the end, I changed out my passenger side axle, and all was well from there.
Hope that helps.
Hope that helps.
just got my axles from Marty @ Raxles.com he is good was going to put them on today but my boy had to do some last minute Xmas shopping going to do it tomorrow see what happens Keep you posted
PS
MArty top man in axles love the gloves and the "hanki" he provided, but wow when i saw that he even printed out a mapquest map with directions to my nearest UPS in Yonkers NY, I was like dam, I guess all that is said about Marty is all true, if the product is as good as the service and quality of packaging he delivers then we will be in contact for all my axle NEEDS FOR LIFE
GREAT SERVICE and telling like it is nothing but the best
PS
put axles on and dam the same noise a tumping noice **** suckssssss thinking it could be the MId shaft bearing and the tranny bearings
Modified by BlUeHoOdCiViC99 at 4:43 PM 12/27/2005
