tranny problem
Old Dec 21, 2005 | 12:42 PM
obd195gsr's Avatar
Default tranny problem
well its been a while since i posted on here ..but i had a few questions and i need a few opinions... Well i went to a shop in the central florida area to get a price on a turbo kit.. so .. i want to make sure my car was ready for this kit -- so we checked the whole car and then it happened-- recently i changed my axels and the left side that connects to the tranny is fine but on the the right side the black housing is slighty moving back and forth...(when in gear and you let your foot off of the gas a ratteling is heard) ..so my machanic told me it might be the diff.. he wont know till he takes the tranny down (= $350) ... so my question is should i just "rebuild the tranny" ... or just get a type R tranny? or a b16 tranny?is it poss that a lsd could fix this? im kinda leaning towards a type r tranny but im not quite sure which route to take.. thanks ....Jay
Old Dec 21, 2005 | 01:03 PM
lVlemphizStylez's Avatar
Default Re: tranny problem (obd195gsr)
b16 with lsd....or you can pay for the hype R and get the SAME EXACT GEARING with a factory lsd...only for shitloads more money...(HINT: its not worth it)
Old Dec 21, 2005 | 01:07 PM
gt30typer's Avatar
What black part are you rocking back and fourth? On the axle? The inner CV joint? I highly dought that it is your diff, unless you have pieces missing off of the ring gear and or spider gears. I ususally see diff failures associated with one wheel burnouts , things of that nature that destroy the ring gear and the main shaft. Does the tranny make noise at idle ? It could just be an input shaft bearing. If you need help rebuilding it , I could take a look at it but I am in WA.
Old Dec 21, 2005 | 07:46 PM
jizzer671's Avatar
Default Re: tranny problem (gt30typer)
tranny? does your tranny make knocking noises at idle? is it hard to put in gear, does it make a clicking noise while movig foward. you might just need a new axle. get it looked at somewhere else and see what they say
Old Dec 21, 2005 | 07:56 PM
jh2586's Avatar
if you wanna go turbo.. i'd just get a new b18b tranny (LS tranny).
you want a tranny that's nice and long so your turbo has more time to spool up
Old Dec 21, 2005 | 08:39 PM
Default Re: tranny problem (jh2586)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh2586 &raquo;</TD></TR><TR><TD CLASS="quote">if you wanna go turbo.. i'd just get a new b18b tranny (LS tranny).
you want a tranny that's nice and long so your turbo has more time to spool up</TD></TR></TABLE>
ignore this man's post ....do not follow his advice...no matter how hard ppl try to educate ppl there will always be those set in their wrong ways...
Old Dec 21, 2005 | 08:45 PM
intekragsr's Avatar
omfg not this **** again. someone add a filter to th forum to screen this bullshit about ls trannys.
Old Dec 22, 2005 | 10:51 AM
obd195gsr's Avatar
well 2morrow im gonna drop the tranny ..and see whats the deal
Old Dec 22, 2005 | 11:23 AM
Wayne_Curr's Avatar
Default Re: (obd195gsr)
hahahahaha, i hate my LS tranny. Only good thing is that I can cruise on the freeway at 2.5k =P
MR.B20VTEC
Jul 18, 2008 02:18 AM
RA050826
Jul 5, 2008 08:43 AM
boudz
Oct 3, 2007 11:38 AM
DeviousCTR
Jan 31, 2006 04:13 PM
ace4nwk
Oct 12, 2004 04:08 PM
