oil leak...
Old Dec 21, 2005 | 11:48 AM
CiSmoEk4's Avatar
Default oil leak...
i just replaced a b16 block in my ek with another b16.. the problem is that when i start the car oil leaks from the passenger side of the motor below the dizzy (no not the dizzy o-ring). it looks like its coming from in between the block and the head. I also have both dowel pins in. I have taken the head off and replaced the head gasket w/ a new honda one and torqued everything to spec and yet this still happens. what should i do?
Old Dec 21, 2005 | 11:49 AM
CiSmoEk4's Avatar
Default Re: oil leak... (CiSmoEk4)
also..im pretty surei have the head gasket on correctly because it says "UP" on it.
Old Dec 21, 2005 | 11:59 AM
postman's Avatar
might be coming from the cam seal. typical problem
Old Dec 21, 2005 | 12:13 PM
CiSmoEk4's Avatar
Default Re: oil leak... (postman)
no its not the cam seal...the oil is leaking on the plateau where the block and tranny come together.
Old Dec 21, 2005 | 12:23 PM
typeoneeg6's Avatar
i had the same problem. its probably running down the head where you cant see it( its pretty tight in there. i replaced cam seal(plug) and vtec soleniod o-ring and it stopped.
Old Dec 21, 2005 | 12:26 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: oil leak... (typeoneeg6)
Yeah, most likely its not comming from there
Old Dec 24, 2005 | 06:52 PM
CiSmoEk4's Avatar
im really wondering if the block just needs to be decked or something because my head was just milled to make sure it was flat. it could be possible that the block was warped right?
Old Dec 24, 2005 | 06:56 PM
Crx Jimmy's Avatar
Default Re: (CiSmoEk4)
it could also be leaking through the dizzy and leaking out of the bottom of the cap, i had this problem on a 200,000 mile motor it was just worn out remove the cap and see if you see oil
Old Dec 24, 2005 | 07:02 PM
dohcdelsol93's Avatar
Default Re: (Crx Jimmy)
I really sounds like it's coming from the dizzy or cam cap seal. Being that the head has been removed and installed a few times from what you've said it probably wouldn't be a bad idea to have the head checked. Just for ships and giggles clean your block and head very well on that leaky side with some degreaser or carb/brake cleaner and let it dry. Then spray some spray anti-persperant deoderant on the area above and below the possible leak. Make sure you use spray deoderant because it will dry white. The source of your leak will show very quickly when you start up the car.
Old Dec 24, 2005 | 07:07 PM
Everyones Hero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiSmoEk4 &raquo;</TD></TR><TR><TD CLASS="quote">im really wondering if the block just needs to be decked or something because my head was just milled to make sure it was flat. it could be possible that the block was warped right?</TD></TR></TABLE>
That's what I was going to suggest.
You could always check to see if the block is warped before you pull it all out.
Old Dec 25, 2005 | 05:56 PM
CiSmoEk4's Avatar
yeah im really sure that the leak is not coming from the cam seal or dizzy o ring. i have a really good feeling that the block was warped because i had just gotten my head milled before i had put the motor together.
BigDare23
13
Oct 15, 2010 03:02 PM
saemoonyang
12
Jun 7, 2010 02:01 PM
scspeed
Mar 28, 2010 06:50 AM
mouab18c1
Jan 26, 2010 12:43 PM
ALL MOTOR DA
11
May 1, 2006 02:48 PM
