PROTHANE MOTOR MOUNTS
yes, def, because u only have the power that you can put down, the prothane mounts help you put the power of ure engine to the ground, not saying its a huge diff, but yes their will be a diff, help get better traction when launching, also keeps the motor in place if spinning the tires.
Guest
Posts: n/a
Spend a little more and get a set of these!!
https://honda-tech.com/zerothread?id=145490
