Quick adapter plate question for sohc turbo
Old Dec 20, 2005 | 07:28 PM
LaOstha's Avatar
Default Quick adapter plate question for sohc turbo
I have a d16z6..Can i use the stock mani and make an adapter plate for the t25. Only reason i ask is cuz every one uses hf or std. Jus tryin to save a lil money
Old Dec 20, 2005 | 08:00 PM
splitime's Avatar
Default Re: Quick adapter plate question for sohc turbo (LaOstha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaOstha &raquo;</TD></TR><TR><TD CLASS="quote">I have a d16z6..Can i use the stock mani and make an adapter plate for the t25. Only reason i ask is cuz every one uses hf or std. Jus tryin to save a lil money</TD></TR></TABLE>
If you have a cat in the front of your motor... then you can use one (you have HF/STD/CX manifold). Normally a z6 does not have this though
The stock manifold is 2 piece and will put the turbo... pretty much under the car.
A hf manifold will cost you at MAX... 50bucks.
Old Dec 21, 2005 | 12:53 PM
LaOstha's Avatar
Default Re: Quick adapter plate question for sohc turbo (splitime)
ohhh ic now thanx
99hatchboy
Mar 6, 2005 11:35 AM
wildcard69
Jan 5, 2005 03:42 PM
sinfulj32
Nov 14, 2004 06:53 AM
iNetForce
Apr 28, 2004 04:00 AM
