Best All Motor Pistons??
https://honda-tech.com/zerothread?id=1339161
These look good though. I would run these with the crower maxi lite rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidd_drastic »</TD></TR><TR><TD CLASS="quote">what about the eagle h beam rods</TD></TR></TABLE>
I run Eagle rods too. The above is if you have the cash.
Can't go wrong with Wiseco and CP pistons, Wiseco's run cheaper, thats why I went with them.
Well you said you want a bore of 84+... so i was jst curious u boring out an LS block or using a B20 block...
jst curious... that ok with you...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidd_drastic »</TD></TR><TR><TD CLASS="quote">I'm deciding on which pistons would be best and the most reliable for an all motor setup w/ an oversized bore. Je, Arias, Wiseco, CP, or any other pistons. </TD></TR></TABLE>
the Endyn rollerwaves are awesome ... you can use very high compression and get away with pump gas. They are custom made Wiseco pistons, all sharp edges are hand sanded.
http://www.theoldone.com
