1st Gen Talons and Eclipses
Old Dec 20, 2005 | 06:43 PM
cityofcaterpillars's Avatar
Default 1st Gen Talons and Eclipses
Yeah I know this is Honda-tech but I wanted to see some 1st Gen DSM's cause I may be getting one very soon and I wanted some insperation. Any sites would be helpful too.
Thanks,
Dan
Old Dec 20, 2005 | 06:53 PM
Default Re: 1st Gen Talons and Eclipses (cityofcaterpillars)
No one wants to help me out??
Old Dec 20, 2005 | 06:56 PM
Old Dec 20, 2005 | 07:07 PM
chet's Avatar
here's my old 1g awd.
Old Dec 20, 2005 | 07:10 PM
Default Re: 1st Gen Talons and Eclipses (chet)
sweet are there anythings in particular I should look for when I go to look at this car I might get??
Old Dec 20, 2005 | 07:16 PM
VRD^sam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cityofcaterpillars &raquo;</TD></TR><TR><TD CLASS="quote">sweet are there anythings in particular I should look for when I go to look at this car I might get??
everything and make sure it goes in gear before you buy it
Old Dec 20, 2005 | 07:21 PM
Default Re: 1st Gen Talons and Eclipses (elf_vang)
I was told it may need a new clutch fork. Will this be a hard or expensive fix? The car is only $700 (from a friend of a friend) so I expect to have to fix some things
chet's Avatar
dsm's are somewhat complicated compared to honda's.
you need to make sure the motor, turbo and clutch are in good shape. these cars have been beaten on as hard or harder compared to honda's and because they are easy to make power with...the previous owner has probably attempted to make more power. while its easy to put a 16g on a dsm and run 12's...most people do it without the right fuel control...without the right clutch...and then run into issues that they wouldn't have otherwise had if the car had been built accordingly.
if you find a clean, all original awd you'll be doing really well. i'd look to spend around 2500 on an awd...or about 1800 on a fwd turbo.
Old Dec 20, 2005 | 07:28 PM
The one I'm looking at is a 90 AWD Turbo. All he has done to it are exhaust, guages, and BOV (which will be comming off if I get it.) $700
Old Dec 20, 2005 | 07:36 PM
.Rex's Avatar
http://www.dsmtuners.com
thers a lot to read about talons and eclipses before buying one.. this site helped me a lot
Old Dec 20, 2005 | 07:40 PM
Default Re: 1st Gen Talons and Eclipses (CarbonCivic)
yeah I just found that sight. It doesnt look like there's much in the way of tasteful cosmetic mods. No 2million lip kits like Hondas
Old Dec 20, 2005 | 07:48 PM
.Rex's Avatar
ya stock body and stock ride height too...weird
if u go to the FAQ's you will learn a lot too btw
Old Dec 20, 2005 | 08:28 PM
bump before bed cause I know this will be lost by morning
Old Dec 20, 2005 | 10:59 PM
chet's Avatar
http://www.vfaq.com is the best resource besides http://www.teamnabr.com.
unfortunately the nabr boards are usually closed for new registration.
also...its good to find your local .dsm.org site.
tampabay.dsm.org and orl.dsm.org are great local resources for everyone in the central/west central florida region.
Old Dec 21, 2005 | 12:13 AM
badboyr66's Avatar
If it is a 1G.... get used to it. There is nothing to make them look well other than rims and suspension. I miss mine. At 15lbs I did 13.32... car was stolen at 18 lbs. Fast as all hell. Freinds shop has a 1GB that did over 600 hp... I canot wait to see it go down the track this next year
Old Dec 21, 2005 | 12:39 AM
LOwrestling2001's Avatar
and3man
Feb 21, 2008 03:16 PM
stemiched
69
Jan 13, 2007 05:01 AM
jamezzz122
Jun 20, 2005 12:08 PM
AWR19
Dec 20, 2003 01:17 AM
tonylude94
Oct 28, 2003 05:10 AM
