Euro Civic Type R 5-lug question
Old Dec 20, 2005 | 05:30 PM
mrlegoman's Avatar
Default Euro Civic Type R 5-lug question
No luck with search. No luck in Suspension forum. I'm sure this has been hashed out before.
What is the difference between the civic type r 5-lug compaired to the us ITR 5-lug?
Wheel bearing size the same? Rotors, calipors, lca's?
Old Dec 20, 2005 | 05:38 PM
ecahatch's Avatar
Senor Miembro
Default Re: Euro Civic Type R 5-lug question (mrlegoman)
hmm all i can think of right now is axle size, ITR is 36mm and CTR is 32mm and ITR uses CUP Type Rear LCA and CTR uses FORK Type Rear LCA
anyone else care to add?
Old Dec 20, 2005 | 06:05 PM
RedEK9's Avatar
Default Re: Euro Civic Type R 5-lug question (ECAhatch)
I think that's about it. both would work I believe, only prob is getting those replacement 36mm axles, I think those are exlusive to j-spec ITR. Other than that, I think ECA handled the rest
Old Dec 20, 2005 | 07:04 PM
hialeahzbg's Avatar
i believe crv is 36 mm
Old Dec 20, 2005 | 07:17 PM
mrlegoman's Avatar
Default Re: (hialeahzbg)
Every so often I see someone selling a CTR 5-lug swap. So if the CTR is 32mm and you have a GSR/ITR tranny (which would be 36), how do you fit the axle? Do they make a 32/36 axle? Or would you have to buy one of each and then make your own?
Old Dec 20, 2005 | 07:28 PM
Aquafina's Avatar
Default Re: (mrlegoman)
CTR is 32mm.
Differences between CTR and ITR are the rear LCA's and the trailing arms.
You'll need Integra rear soft lines for a 96-00 Civic.
Link to my Write up on 5-lug on a 96 hatch is in my biography.
Old Dec 22, 2005 | 01:30 PM
mrlegoman's Avatar
Default Re: (Aquafina)
Nice write up!
But basically a CTR spindle will not work with an ITR tranny because there is no such thing as a 32-36 axle, correct?
SoCal EJ1
May 13, 2008 01:01 PM
lv6l
11
Mar 28, 2006 12:42 PM
heartmyEG6
May 10, 2004 10:23 AM
EF4lyfe
Jan 28, 2004 09:11 AM
EhSiRk92
Aug 18, 2002 02:49 PM
