eg tps plug
Old Dec 20, 2005 | 03:37 PM
1sikhatch's Avatar
Default eg tps plug
ok i just did a z6 swap on my eg but i'm using the cx harness and my car revs funny so i looked at all my wiring and evberything looks fine but on my tps the plug is (left-right) red, yellow, green and on my friends eg its green , red yellow. should i change my wires around or is it the correct way?
Old Dec 21, 2005 | 03:50 AM
1sikhatch's Avatar
Default Re: eg tps plug (1sikhatch)
up
Old Dec 21, 2005 | 09:57 AM
gt30typer's Avatar
The real only way to be sure is to test the output and input from the ECU to those wires. The center wire should be your signal wire , which is usually a red/blk. The yellow wire which is usually on the left side of the plug is the signal wire, the green wire is the sensor ground. Check to see whether or not you are recieving a ~5V signal to the yellow wire, if not check the other wires and see if it going to the other ones. You can also check continuity between the green wire and a body ground.
Old Dec 22, 2005 | 05:58 AM
1sikhatch's Avatar
Default Re: eg tps plug (gt30typer)
yes the yellow wire is getting current but not the red one. also when i plug out the tps the car revs a little better
Old Dec 22, 2005 | 01:03 PM
gt30typer's Avatar
plug in the red wire and use a multimeter to check to see you are recieving ~.5 V when throttle is closed and 4.5V when it is fully open. If you are not getting any voltage check to make sure there is not a short or open in the wire, also Check continuity between the green wire and a chassis ground
jdmsir4dr
Apr 25, 2013 08:33 PM
BoostedSiEM1
Sep 23, 2012 02:25 PM
b16ahybrid
Mar 7, 2004 08:52 PM
