would a modified y8 headgasket leak ?
Old Dec 20, 2005 | 01:06 PM
97grnrs's Avatar
Default would a modified y8 headgasket leak ?
i wanna take the middle layer out of my y8 gasket i just bought but isnt that layer there for a reason? will it leak or not seal right if i remove it or no?
Old Dec 20, 2005 | 01:18 PM
Turbo_y8's Avatar
Default Re: would a modified y8 headgasket leak ? (97grnrs)
why do you want to do this
Old Dec 20, 2005 | 01:22 PM
SOHC4life 96's Avatar
Default Re: would a modified y8 headgasket leak ? (tuck'd98)
Probably to lower the compression ratio. I doubt it will work though.
Old Dec 20, 2005 | 01:24 PM
Turbo_y8's Avatar
Default Re: would a modified y8 headgasket leak ? (SOHC4life 96)
yea i know thats what he is going for i wanted him to say that and then laugh at the stupidity of it
Old Dec 20, 2005 | 01:25 PM
lilscott's Avatar
just buy a 1 or 2 layer headgasket in the first place
1point7db2's Avatar
I would also like to know this. They are three layer gaskets, I've heard of people seperating them but wasn't sure.
Old Dec 20, 2005 | 01:26 PM
1point7db2's Avatar
Default Re: would a modified y8 headgasket leak ? (blownEG93)
Can you buy 1 or 2 layer? They always give me 3-layer when I buy a Y8 gasket.
Old Dec 20, 2005 | 01:37 PM
Jay_Sensing's Avatar
Yes, they make aftermarket ones. You can't buy an OEM 1 or 2 layer.
And you add to lower compression, he is wanting to remove to bump compression.
Don't do it lol, check out inline four, password, site like that. They are out there.
Old Dec 20, 2005 | 01:46 PM
97grnrs's Avatar
Default Re: (Jay_Sensing)
ive heard of ppl doing it so someone must have tried it. it seperates easily but as long as it would not leak , i just want to know from someone who has used it like this already
Old Dec 21, 2005 | 06:23 AM
97grnrs's Avatar
up
Old Dec 21, 2005 | 06:26 AM
Everyones Hero's Avatar
You should have bought a Z6 gasket if you're trying to raise compression.
A lot of turbo guys use Y8 headgaskets on their Z6 turbos to lower compression.
Old Dec 21, 2005 | 03:51 PM
97grnrs's Avatar
Default Re: would a modified y8 headgasket leak ? (Everyones Hero)
i thought a z6 and y8 gasket are the same part number
Old Dec 22, 2005 | 05:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i thought a z6 and y8 gasket are the same part number </TD></TR></TABLE>
102603 006 1 GASKET, CYL HD for 1995 D16Z6
18140 006 1 GASKET, CYL HD for a 1996 D16Y8
Those are the part numbers from http://www.hondaautomotiveparts.com
Old Dec 22, 2005 | 06:01 AM
97grnrs's Avatar
oh i dunno. on the compression calc site it has an option for stock z6/y8 gasket giving a compression of like 9.6 to one or something , but then it also says "2 layer y8 gasket" which gives like a 10.2 : 1 ratio. so i dunno. i jus wanna hear from someone who has used it seperated before and know if it works.
Old Dec 22, 2005 | 06:44 AM
dohcVTECeg2's Avatar
like nike....just do it
Old Dec 22, 2005 | 07:07 AM
Default Re: would a modified y8 headgasket leak ? (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">like nike....just do it </TD></TR></TABLE>
What the expletive? You say the stupidest, most worthless ****.
jdmhonda123
Dec 1, 2010 10:28 PM
mattie_96
Sep 11, 2006 03:14 PM
baggedmazda
May 7, 2006 03:55 PM
roycivic92
Jan 10, 2005 06:14 AM
cottagecreep
17
Apr 19, 2003 12:31 AM
