would a modified y8 headgasket leak ?
i wanna take the middle layer out of my y8 gasket i just bought but isnt that layer there for a reason? will it leak or not seal right if i remove it or no?
Re: would a modified y8 headgasket leak ? (97grnrs)
why do you want to do this
Re: would a modified y8 headgasket leak ? (tuck'd98)
Probably to lower the compression ratio. I doubt it will work though.
Re: would a modified y8 headgasket leak ? (SOHC4life 96)
yea i know thats what he is going for i wanted him to say that and then laugh at the stupidity of it
just buy a 1 or 2 layer headgasket in the first place
I would also like to know this. They are three layer gaskets, I've heard of people seperating them but wasn't sure.
Re: would a modified y8 headgasket leak ? (blownEG93)
Can you buy 1 or 2 layer? They always give me 3-layer when I buy a Y8 gasket.
Yes, they make aftermarket ones. You can't buy an OEM 1 or 2 layer.
And you add to lower compression, he is wanting to remove to bump compression. Don't do it lol, check out inline four, password, site like that. They are out there. |
Re: (Jay_Sensing)
ive heard of ppl doing it so someone must have tried it. it seperates easily but as long as it would not leak , i just want to know from someone who has used it like this already
up
You should have bought a Z6 gasket if you're trying to raise compression.
A lot of turbo guys use Y8 headgaskets on their Z6 turbos to lower compression. |
Re: would a modified y8 headgasket leak ? (Everyones Hero)
i thought a z6 and y8 gasket are the same part number
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">i thought a z6 and y8 gasket are the same part number </TD></TR></TABLE>
102603 006 1 GASKET, CYL HD for 1995 D16Z6 18140 006 1 GASKET, CYL HD for a 1996 D16Y8 Those are the part numbers from http://www.hondaautomotiveparts.com |
oh i dunno. on the compression calc site it has an option for stock z6/y8 gasket giving a compression of like 9.6 to one or something , but then it also says "2 layer y8 gasket" which gives like a 10.2 : 1 ratio. so i dunno. i jus wanna hear from someone who has used it seperated before and know if it works.
like nike....just do it https://honda-tech.com/forums/images...s/emsmilep.gif
Re: would a modified y8 headgasket leak ? (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">like nike....just do it https://honda-tech.com/forums/images...s/emsmilep.gif </TD></TR></TABLE>
What the expletive? You say the stupidest, most worthless shit. |
