h22 doesn't rev past 6200rpm even w/ P13 ECU
Old Dec 20, 2005 | 12:19 PM
acclude-vtec's Avatar
Default h22 doesn't rev past 6200rpm even w/ P13 ECU
why, doesn't my h22 rev past 6200rpm even with P13 ECU...engine harness made by hasport...check engine light spits out knock sensor code... Changed it twice (one from a B16A & the other from the dealer new)....why oh why? and i still get the knock sensor code...what do i do next?
Old Dec 20, 2005 | 12:32 PM
SteveoBA8's Avatar
Default Re: h22 doesn't rev past 6200rpm even w/ P13 ECU (acclude-vtec)
Did you check for continuity from the knock sensor engine harness connector and the ecu pin D3? What model is your lude to start with?
Old Dec 21, 2005 | 09:48 AM
Default Re: h22 doesn't rev past 6200rpm even w/ P13 ECU (SteveoBA8)
93 h22a Vtec and i rewired straight from the knock sensor to the ECU Pin D3 OBD I
Old Dec 21, 2005 | 10:01 AM
SteveoBA8's Avatar
did you use a shielded wire?
Old Dec 22, 2005 | 05:53 AM
no i didn't, but it doesn't matter know...just work up this morning and the car rev up to 8000rpm...my vtec wasn't opening up before (I did everything)...then a couple days ago i decided to bang out the oil pan (it was dented in)...lucky me, it didn't bend the pump...so now vtec opened up now, but i could rev past 6200rpm...i'm guessing it needed some time to adjust...today it works, but i still have the knock sensor code...not affecting the performance, so it doesn't bore to much...the only thing that bothers is the check engine light on....yes, i reseted it 100's of times (disconnecting the battery & unpluging the ECU... now that it works i reset it one time, and then we'll see.....hot deals!!!!couldn't get any better then that!!!
BowtieHonda
Nov 28, 2012 11:41 PM
more3688
Feb 23, 2010 11:09 PM
jdm_cd5
Nov 3, 2007 10:48 PM
Stillo
Oct 5, 2007 07:09 PM
st0nedstoopid
Aug 18, 2003 04:55 PM
