How do I replace a radiator?
Old Dec 20, 2005 | 12:00 PM
97LXAcc0rd's Avatar
Default How do I replace a radiator?
Hello! Winter season creeped up and i've ran into another car dilemma. Today I noticed while driving i saw a little smoke/steam rising from the crevices of my hood. I stopped the car and noticed that the radiator, in front of the two big fans was leaking smoke. Apparantly a little piece just started cracking. Now, right next to the radiator cap about an inch away is the crack about an inch long. I'll be taking pictures tonight to be sure of it. Anyways, where can I buy one of these cheap and where do I go to get it installed? Is it easy to put in? What caused the crack? Help would be highly appreciated, thanks.
Old Dec 20, 2005 | 12:04 PM
YeuEmMaiMai's Avatar
Default Re: How do I replace a radiator? (97LXAcc0rd)
1. make sure car is cold
2. open hood
3 remove a/c bracket bolts
3 remove fan
5 remove top rad support bolts
6. remove trans cooler lines and cap with foil or suitable material
7. place pan under rad adn drain
8. remove lower hose
9. remove upper hose
10 remove rad
replace all hoses and cap when you reinstall.
Old Dec 20, 2005 | 12:14 PM
97LXAcc0rd's Avatar
THERE'S A PICTURE! HELP PLEASE!!! How much do radiators usually cost?
Old Dec 20, 2005 | 01:45 PM
i_kick_turtles's Avatar
Check out:
http://www.radiatorbarn.com/
http://www.radiators.com/
http://www.coolradiator.com/index.htm
I don't have any experience with the first two, but I've been told radiatorbarn has really fast shipping.
Old Dec 20, 2005 | 02:28 PM
zumiez007's Avatar
Default Re: How do I replace a radiator? (I R Tylor)
Ebay. Koyo Radiators with lifetime warrenty. ~$100
Old Dec 20, 2005 | 05:11 PM
97LXAcc0rd's Avatar
I have a quick question, will there be any problems if i just ride on the current radiator like that for now? What will happen if i do? Can't i just tape it up or something? Thanks.
Old Dec 20, 2005 | 05:29 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: How do I replace a radiator? (zumiez007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumiez007 &raquo;</TD></TR><TR><TD CLASS="quote">Ebay. Koyo Radiators with lifetime warrenty. ~$100</TD></TR></TABLE>
I think thats where my friend got his last fall. It looked like a decent unit. It was just a stock replacement, nothing fancy. It's been in there for more than a year now and he hasn't had any problems thus far. ::knocks on wood::
Old Dec 20, 2005 | 05:55 PM
civicboisi's Avatar
Default Re: (97LXAcc0rd)
a buddy of mine drove his GSR like this for awhile, but we applied some JB Weld on it to hold it somewhat...ultimately, you'll have to replace the radiator.
think about it this way too...replace the rad for 100 bucks...or pay for the tow to get it to your house or a garage
Old Dec 20, 2005 | 06:19 PM
CRXb18Turbo's Avatar
Default Re: (civicboisi)
you could use jb weld it for right now.
just sand it down so it'll grip good.
or you would mig/tig weld it.
Old Dec 20, 2005 | 07:10 PM
Topnotcheez's Avatar
here's some advice. Do it yourself. I got a friend of mine (a Honda Tech) to do it, cost me like $450. After I wrecked my car, I took out the Rad to fix my front end...no big deal. Just mark everything (where you got it from). Also DO NOT REMOVE THE AC COMPRESSOR. Its the smaller looking "radiator" in front of the actual Rad. If you unsrew it...You will have to recharge your AC...(scared the crap out of me)...
Old Dec 20, 2005 | 07:58 PM
deserthonda's Avatar
Default Re: How do I replace a radiator? (Topnotcheez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topnotcheez &raquo;</TD></TR><TR><TD CLASS="quote"> Also DO NOT REMOVE THE AC COMPRESSOR. Its the smaller looking "radiator" in front of the actual Rad. If you unsrew it...You will have to recharge your AC...(scared the crap out of me)...</TD></TR></TABLE>
just for the record that is the A/C CONDENSOR ,,..
Old Dec 20, 2005 | 08:01 PM
Brycen's Avatar
Default Re: How do I replace a radiator? (deserthonda)
yea that sucks samething happend to my 94 sprayed crap everywhere car was smoking looked like and idiot.
Old Dec 20, 2005 | 08:08 PM
replace the radiator.. tape does not work, jb weld is only temorary,, and the leak might get worse .causing an overheating and possible more expansive problems..........It is not that hard to replace just follow YEU's directions and don;t forget to bleed system when done..
Old Dec 20, 2005 | 08:51 PM
hondadude's Avatar
Here is a link to a toyota radiator replacement very close to the honda accord,
Best of luck I hope this helps you
http://www.troublecodes.net/ar...shtml
guille595
Dec 6, 2009 05:09 PM
VR4ownzU
Feb 3, 2009 12:06 PM
TMC_EF
Jul 1, 2007 08:57 PM
darkfx
Sep 28, 2005 06:31 PM
Black96Cobra
Jul 28, 2001 06:28 PM
