tranny problem/ question
Old Dec 20, 2005 | 09:18 AM
90civSi's Avatar
Default tranny problem/ question
ok i just put in the b16 swap with the y1 lsd tranny, for some reason its pops out of 5th gear. talking to my one friend he said there is a way to adjust it? is there a way to do that or what could be the problem??
Old Dec 21, 2005 | 10:43 AM
90civSi's Avatar
bump
Old Dec 21, 2005 | 07:01 PM
jdmcars.com's Avatar
Default Re: tranny problem/ question (90civSi)
If it is popping out, and your shift linkage is installed correctly, it is probably something bad internal of the transmission.
Will it engage into 5th, and then only pop out if you smash on the gas or what?
Old Dec 21, 2005 | 07:15 PM
SD_Lurker's Avatar
HT White Ops
Default Re: tranny problem/ question (jdmcars.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com &raquo;</TD></TR><TR><TD CLASS="quote">If it is popping out, and your shift linkage is installed correctly, it is probably something bad internal of the transmission.
Will it engage into 5th, and then only pop out if you smash on the gas or what?</TD></TR></TABLE>
I agree. If linkage is installed right then you have another problem on your hands. I would say that your tranny make be fu..ked but dont quote me on it. Good Luck
Old Dec 21, 2005 | 08:30 PM
90civSi's Avatar
well im pretty sure that my shift linkage is hooked up right i mean it only really goes one way.
and it just seems like it will pop out anytime just when im cruisin, seems like it will do it more when im going faster but not accelerating. and it is also makin like a rattle noise or something weird up to like 55 but after that it stops.
90civSi's Avatar
oh yes it will go into fifth
Old Dec 22, 2005 | 05:44 AM
Sgt_Ox's Avatar
had that same problem with my brothers 90 Integra. His tranny was f*cked though.
Old Dec 29, 2005 | 03:52 PM
integra95gsr's Avatar
could it have anything to do with it having a short throw shifter on it. it feels like it doesnt have enough throw to put it all the way into the gear.
Old Dec 29, 2005 | 06:36 PM
D Rex's Avatar
If it's not the linkage then it's a synchro going out. Try running synchomesh fluid in it before you pull it out. It might hide the problem for a while and it's about $15 buck. Good luck
badass3dr
Transmission & Drivetrain
11
Mar 20, 2014 07:32 PM
Timmyflys
Aug 13, 2007 03:34 PM
CRX2112
Nov 14, 2006 12:04 AM
951dc5
Jan 22, 2005 05:38 PM
VtecDA9
Aug 4, 2003 06:33 AM
