b16 and b18c5
Old Dec 20, 2005 | 07:31 AM
pcp 914's Avatar
Default b16 and b18c5
can you tell the diffrence besides the vailecover and intakemanifold between the b16 and b18c5 head while its already in the car for example an id# or something also the same for cam shafts and trans
Old Dec 20, 2005 | 07:40 AM
Dave_B's Avatar
The B18C5 stamping on the engine. Trans if USDM should be JH4 IIRC.
Old Dec 20, 2005 | 08:59 AM
pcp 914's Avatar
Default Re: b16 and b18c5 (pcp 914)
yea, but i was wondering if u could tell what head would be on the block
Old Dec 20, 2005 | 09:32 AM
jdm_DC2R's Avatar
correct me if im wrong, but im sure there is no markings on the outside so u can tell one from the other....only the internals are different, but as far as i know and can remember, no visual markings on the head itself. Could be wrong tho...
Old Dec 20, 2005 | 09:37 AM
98 Spec R's Avatar
Type R heads have green paint on the top of the cam cap by the distributor.
BlueR's Avatar
Default Re: (jdm_DC2R)
an untampered ITR head will have a patch of green paint behind the distributor
if you are able to see, the intake ports will also have some mild porting
Old Dec 20, 2005 | 09:57 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">an untampered ITR head will have a patch of green paint behind the distributor
if you are able to see, the intake ports will also have some mild porting</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">Type R heads have green paint on the top of the cam cap by the distributor. </TD></TR></TABLE>
Both USDM and JDM will have this mark.
Old Dec 20, 2005 | 02:17 PM
Hooch'n's Avatar
Default Re: (walker111)
My jdm b16 has green on it, also the differences are PR3-#
My jdm b16 is a pr3-3
my USDM b18c5 is a pr3-4
only other difference is inside the head, the c5 has some mild head work.
Old Dec 20, 2005 | 06:42 PM
Rene M's Avatar
Default Re: b16 and b18c5 (98 Spec R)
No ****? thats what that stuff was.. And here i workd real hard to get rid of it..
Oops..
Old Dec 20, 2005 | 07:32 PM
s2kdre's Avatar
Default Re: b16 and b18c5 (Rene M)
intake manifolds are way different. tb is 68mm
Old Dec 20, 2005 | 08:35 PM
Mythias's Avatar
You can determine which is which by examining the bowl work.
Old Dec 20, 2005 | 11:57 PM
Pondus's Avatar
Default Re: (Hooch'n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n &raquo;</TD></TR><TR><TD CLASS="quote">My jdm b16 has green on it, also the differences are PR3-#
Well, my ITR head is a PR3-3 so that is no way to distinguish between them.
The ITR head also has dual valvesprings on both exhaust and intake, you can check this by removing the valvecover. Bowl work is hard to see without removing the head from the block, and to check the cams you would have to remove the cam caps so that's a bit more work.
crxvtecturbo
May 10, 2014 05:12 PM
johnnybronx
Feb 15, 2009 05:07 AM
krazych0p
Mar 25, 2008 02:59 PM
moz92
20
Feb 10, 2007 07:15 PM
vlc92189
Jun 21, 2006 05:35 AM
