distributor
Old Mar 21, 2008 | 06:34 PM
krazych0p's Avatar
Default distributor
i have a 1990 integra ls-vech what kind of distributor do i get ??
Old Mar 22, 2008 | 07:54 AM
j_bizach's Avatar
Default Re: distributor (krazych0p)
you need the one that matches the head that your using so if you got a b16 head (which i asume cause thats what everyone uses) you need to find a b16 dizzy.
Old Mar 22, 2008 | 07:57 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: distributor (j_bizach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_bizach &raquo;</TD></TR><TR><TD CLASS="quote">you need the one that matches the head that your using so if you got a b16 head (which i asume cause thats what everyone uses) you need to find a b16 dizzy.</TD></TR></TABLE>
Exactly
Old Mar 23, 2008 | 07:13 PM
krazych0p's Avatar
is there any way i can find out what type of v-tech head i got b/c i bought the car already ls-v
Old Mar 24, 2008 | 06:58 AM
j_bizach's Avatar
ther should be a code on the head somewhere.
Old Mar 24, 2008 | 08:08 AM
BryanM.'s Avatar
Resident Gearhead
PR4/P75 - B18B/B20
P72/GSR - B18C(1)
P30/PR3/P73 - B16 OBD0 - B16 OBDI/II - ITR
<u><FONT COLOR="red">(I believe this info is correct, someone please chime in if it's not)</u></FONT>
Head # can be found above and to the right of cylinder #2 exhaust port.
Mine is a 92-95 SiR-II B16A PR3
Modified by mcvtec at 6:44 PM 3/24/2008
Old Mar 24, 2008 | 02:39 PM
krazych0p's Avatar
Default Re: distributor (mcvtec)
thanks 4 the info
Old Mar 24, 2008 | 02:43 PM
BryanM.'s Avatar
Resident Gearhead
No problem brozef
Old Mar 24, 2008 | 03:31 PM
krazych0p's Avatar
i just checked my head and it says pr3-1 what type is that
Old Mar 25, 2008 | 09:27 AM
B18C5-EH2's Avatar
Former Moderator
Loved
You need to tell us if the distributor plugs are currently grey or mily white/clear.
Grey = OBD1, and you need to roder the distibutor for a 1992/1993 Integra GS-R which is a part number TD44.
Milky white/clear = OBD0 and you need to roder a JDM OBD0 "first-gen" B16A distributor with part number TD22U
The head type doesn't matter at all - the B16A head will accept a OBD0, OBD1, or even OBD2 distibutor - the bolt pattern/body is all the same for B series VTEC. It's the internals and plugs that make the difference.
By the way Distributor King/Richporter technologies makes the best brand new replacement distributors for our cars. They can be found online and on Ebay most likely. Google "Distributor King Richporter" and see what you get, then order either part number I listed above depending on which OBD type you have.
Modified by B18C5-EH2 at 1:42 PM 3/25/2008
Modified by B18C5-EH2 at 1:53 PM 3/25/2008
Old Mar 25, 2008 | 09:35 AM
John M's Avatar
Default Re: distributor (B18C5-EH2)
vtec
Old Mar 25, 2008 | 09:48 AM
lsvtecboi'95's Avatar
wtf is ls/ (vech)... and there is no H
Old Mar 25, 2008 | 10:16 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (lsvtecboi'95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecboi’95 &raquo;</TD></TR><TR><TD CLASS="quote">wtf is ls/ (vech)... and there is no H</TD></TR></TABLE>
Well if you're trying to be picky then you both forgot the "T" in "VTEC" but you obviously know what he meant.
A guy with 50 posts busts in trying to make someone else feel stupid...
If you can't help the guy or answer any tech info for the topic at hand GTFO, thanks.
Old Mar 25, 2008 | 02:59 PM
krazych0p's Avatar
Default Re: (B18C5-EH2)
thanks 4 the help
EG2_AP1_AE86
Sep 8, 2009 07:28 AM
Rightside
Jul 12, 2004 10:12 PM
Stunna BEN
Jan 27, 2003 06:37 PM
