Car STILL won't start...
Old Dec 20, 2005 | 05:24 AM
eurodeseo's Avatar
Default Car STILL won't start...
You guys helped me out a couple weeks ago when I was trying to diagnose what's wrong w/ my car.
When I turn it on it tries to start, just like normal, except it never fires up. Just keeps trying. No clicking or anything...everything sounds like it should.
I replaced the battery, and it fired up but ran crappy and my lights were dim. I had the alternator replaced next. The car ran like a champ when I picked it up, drove it on Friday and let it sit over the weekend. On Monday it wouldn't start again. I thought the battery might be drained, so I took it to AutoZone. They said it's got a full charge. So now I'm stuck. Again.
Any ideas? Should I check the fuses? If so, which ones?
Old Dec 20, 2005 | 05:36 AM
Dave-ROR's Avatar
Default Re: Car STILL won't start... (eurodeseo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eurodeseo &raquo;</TD></TR><TR><TD CLASS="quote">You guys helped me out a couple weeks ago when I was trying to diagnose what's wrong w/ my car.
Any ideas? Should I check the fuses? If so, which ones? </TD></TR></TABLE>
Any ignition related fuses, but check the ignitor, it's likely bad since it's not the charging system.
Old Dec 20, 2005 | 05:54 AM
eurodeseo's Avatar
Default Re: Car STILL won't start... (Dave-ROR)
Where is the ignitor located and is there a way to test it?
Dave_B's Avatar
The ignitor is internal to the distributer. You will have to take the cap off to get to it IIRC.
Old Dec 20, 2005 | 05:57 AM
Dave-ROR's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">The ignitor is internal to the distributer. You will have to take the cap off to get to it IIRC.</TD></TR></TABLE>
Old Dec 20, 2005 | 07:54 AM
The Tech-1's Avatar
Not too sure what the ignitor is, i'm thinking however the problem is disributor related.
Old Dec 20, 2005 | 10:18 AM
whitelightning's Avatar
Default Re: (The Tech-1)
are you getting spark? i had the same issue for a long time...turned out to be the coil...
Old Dec 20, 2005 | 12:09 PM
ITR092's Avatar
have your ICM(ignition control Module) checked and maybe replace your distributor because that is where the control Module is located.... probably malfunctioning.
Old Dec 20, 2005 | 01:05 PM
The Tech-1's Avatar
Default Re: (whitelightning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitelightning &raquo;</TD></TR><TR><TD CLASS="quote">had the same issue for a long time...turned out to be the coil...</TD></TR></TABLE>
Same with me
Old Dec 20, 2005 | 01:49 PM
rodimus's Avatar
if you ever replace the dizzy make sure it's OEM.
Old Dec 27, 2005 | 08:48 AM
eurodeseo's Avatar
Default Re: (EVOL)
I checked all the fuses and they are fine. I'm getting spark.
The car started the other day and the CEL light came on during my last test drive. I got the "woooom" sound again right before the car died. Could this be a faulty MAP sensor?
At any rate, I'm gonna try to make it to Autozone so they can check the codes.
Old Dec 27, 2005 | 10:19 AM
AntiStock's Avatar
If you have spark, it's probably a sensor or fuel issue. I had the same problem with my old Evo, and it turned out to be a broken crank position sensor, but I'm not sure if the ITR has that or not, sorry
Old Dec 27, 2005 | 02:01 PM
mugenracer's Avatar
Pull the valve cover off and ensure the the timing belt hasnt slipped and is off a tooth or two.
Old Dec 27, 2005 | 02:39 PM
eurodeseo's Avatar
I checked the codes. I'm getting a P0132 which is "O2 Sensor Circuit High Voltage"
Where do I start as far as trying to fix this?
Old Dec 28, 2005 | 05:50 AM
eurodeseo's Avatar
Default Re: (eurodeseo)
Anyone?
Old Dec 28, 2005 | 04:13 PM
heel_touge's Avatar
i dont know about your other thread.
but check the fuses INSIDE the car. i cant remember what it was called. but i know its in there. its a 10 i believe.
there is a fuse that goes bad that runs your alternator and your speedo, its often overlooked but is usually a problem, i have replaced two on different friends cars.
Old Jan 5, 2006 | 09:32 AM
eurodeseo's Avatar
Default Re: (1slowcivic)
Well, after replacing the primary o2 sensor and the fuel filter, the real problem seems to have revealed itself.
My plugs are gas fouled now, so it seems I'm not getting spark. I ordered a new distributor from distributor king...I'm really hoping this fixes it. I wanna drive my damn car
Old Jan 5, 2006 | 03:21 PM
STUCKED's Avatar
had that problem for over a year. did many things to it and its not normal yet. i was told by an acura tech that when trying to start the car the rpm gauge should slightly jump. if it doesnt then the ignitor is out. check that out and see what happens
filipinospeed
Jun 11, 2009 07:14 PM
eg686
Aug 22, 2005 10:16 PM
brad86
May 30, 2004 02:37 PM
Ya@inlinePRO
Aug 6, 2003 12:10 PM
deeeffache
Oct 28, 2002 03:45 PM
