sohc boost question
want to rebuild me d16z6 so i can use more boost a friend of mine suggested boring the block .40 instead of stock bore but wont that raise your compression plan on gettin forged internals block gaurd bearing kit and head bolts and possibly other things but would it be better to bore it out if so what compression pistons should i go with. or is it best to stick with stock bore thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Its better to overbore the cylinders so you know you have a true circle..I would overbore 0.5 though ,, not 0.4 .</TD></TR></TABLE>
hes probably talking 0.040 not 0.4
0.040 is 0.5mm wich is the biggest u can get for aftermarket pistons like JE and still have plenty of sleeve
so would this raise the compression, and if i stick to overboring it what compression should i get the 8:1 or 9:1 thanks for the info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencivic94 »</TD></TR><TR><TD CLASS="quote">so would this raise the compression, and if i stick to overboring it what compression should i get the 8:1 or 9:1 thanks for the info</TD></TR></TABLE>
9:1
9:1
From: University of Massachusetts, Amherst, Ma, US of A
if you plan on boosting I would use 8:1. and as for boring I wouldn't bore too much, you need as much sleeve as possible when boosting, sure a blockguard will help with flexing a lot and is an alternative to using iron sleeves but if you boost way to much say good-bye to your block. Sleeves will only make your block virtually bulletproof
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">8.1 is just to low for street applications i think.
stick with 9.1
platinum.</TD></TR></TABLE>
stick with 9.1
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">
0.040 is 0.5mm wich is the biggest u can get for aftermarket pistons like JE and still have plenty of sleeve</TD></TR></TABLE>
Incorrect.
0.020" is 0.5mm. You bored your block 0.040", which is 1mm over, or 76mm.
Incorrect.
NXAccordTO4B
Jul 19, 2003 08:27 PM
CRVRX
May 27, 2003 07:08 PM
