Removing Alternator in 86-89 Accord
Old Dec 19, 2005 | 07:54 PM
jimeby's Avatar
Default Removing Alternator in 86-89 Accord
I have an '86 Accord 5-spd in which the alternator needs new brushes. The Honda shop manual tells you to pull the left driveshaft in order to remove the alternator! As I don't have a garage or any indoor place to work, is there any way to pull it from above?
jimeby
Old Dec 19, 2005 | 08:14 PM
deserthonda's Avatar
Default Re: Removing Alternator in 86-89 Accord (jimeby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimeby &raquo;</TD></TR><TR><TD CLASS="quote">I have an '86 Accord 5-spd in which the alternator needs new brushes. The Honda shop manual tells you to pull the left driveshaft in order to remove the alternator! As I don't have a garage or any indoor place to work, is there any way to pull it from above?
jimeby</TD></TR></TABLE>
i don't think so ... not enough room
Old Dec 19, 2005 | 08:51 PM
stickercuttingcom's Avatar
You can't pull it from above, you will need to get below.
I can definitely see where you would need to pull the left driveshaft, it is TIGHT in there.
Old Dec 20, 2005 | 04:02 AM
before removing axle,, remove the oil filter and see if you can sneak it out that way
Old Dec 20, 2005 | 09:37 AM
hondadude's Avatar
If you are just replacing the brush pak, don't remove the ALT from the car or pull the drive shaft. just get the battery dis-connected remove the 10mm on the Batt lead and the insulator, swivel the alt. back then remove the 8mm nuts that hold the cover on; next get a GOOD #2 philips bit and there are 2 screws tht hold the brush pak in. When reinserting the new brush pak use a feeler gauge on top of the Alt rotor to help compress the brushes in to their holder.
Best of luck I hope this helps you
Old Oct 19, 2014 | 02:25 PM
SlickStretch's Avatar
I just did this about an hour ago. If You remove the air filter box, you can get it out from above. You'll still need to go underneath to remove the mounting bolt and neg. wire.
Old Oct 20, 2014 | 02:55 AM
Lost Again's Avatar
On the LXi (fuel injected), yes remove the air filter box and lift it out.
On the DX and LX (carb) - you have the "snake" the alt along the firewall, then under/around the heater hoses to the heater core and remove it from the pass side of the car.
I've replaced several alt's on 3rd gen Accords in different trims and have never had to pull the cv shaft.
Old Mar 8, 2020 | 09:07 AM
rwogs's Avatar
I have done this too. It is tight and you have to rotate it a few times to get it right, but it can be done!
grinder_1
Classic Hondas
Sep 19, 2018 03:58 PM
Tcall
Jan 5, 2012 02:18 PM
95/04 Accord
Dec 2, 2009 05:08 PM
GavinJuice
Feb 21, 2009 07:49 AM
nickoz
Nov 23, 2007 10:34 PM
