for the JDM guru's
Old Mar 17, 2002 | 10:51 AM
o.G.A.g.'s Avatar
Default for the JDM guru's
how do u make a jdm motor look legal?
> senario: motor is JDM. year is 91
car is 95 cx.
what can u do to make this legit?
any info is greatly apperaciated. thankx
Old Mar 17, 2002 | 11:19 AM
bearingburner's Avatar
Default Re: for the JDM guru's (kb8)
by law you are not allowed to install an older year engine in any car. example 93 engine in 94 car. you can do this swap only for off road usage like racing, track cars...etc.
Old Mar 17, 2002 | 11:20 AM
o.G.A.g.'s Avatar
Default Re: for the JDM guru's (bearingburner)
thats why im askin if there is any way i can make it legit.
Old Mar 17, 2002 | 11:22 AM
o.G.A.g.'s Avatar
coz i found this motor for hella cheap as in hella cheap but its older than my car. so i wuz wonderin if there is any posibble way of makin it legit without swapping for a new motor.
Old Mar 17, 2002 | 11:25 AM
o.G.A.g.'s Avatar
can u like swap some parts of it?
if you really need to ; if the engine is equipped with a vin# you can remove it. the main thing is setting up evap controls and pcv system. like air box vacuum lines and make sure no headers, msd, or anything of that matter. if everything is hooked up correctly like oem. then you should have no problems. oh one more thing is electrical connectors. make sure no electrical connector open/unplugged. either find a home for them or hide them.
Old Mar 17, 2002 | 11:46 AM
shawnhayes's Avatar
Only in CA is this regulated. Other states only check emissions - if it passes - it passes.
Shawn
Old Mar 17, 2002 | 11:52 AM
Default Re: for the JDM guru's (shawnhayes)
i didnt know that thanks for the info i am a CA resident and didnt know
thanks again now i know
Old Mar 17, 2002 | 01:44 PM
o.G.A.g.'s Avatar
ttt
wantboost1
Nov 24, 2017 03:12 PM
Spiffious
10
Jul 8, 2004 08:55 PM
chris408
Mar 3, 2003 05:41 PM
o.G.A.g.
Mar 18, 2002 10:56 PM
threatcon13
Dec 17, 2001 03:38 PM
