Advantages of a Type R block over a b18a
Ive already purchased rods for my b18a.. And now i have an oppertunity to purchase a Type R block with a spun rod and low miles...
should I even bother, and use my LS crank and Rods in that block...
the guy wants 300 canadian for the block
its for a LS/VTEC setup.. and I plan on buying new pistons also.. but I havent yet
well youd have to have the bearings sized properly due to the spun bearing....but the save in oil plumbing to the head & also the benefit of oil squirters will also aid in being boosted...plus 300 canadian is pretty cheap...plus about 200 in machine work & you have yourself a decent block for cheap money...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bxjdmhatch »</TD></TR><TR><TD CLASS="quote">I'd get the itr block and use the ls crank and rods..sell the ls bare block to make some money bak for machine shop work on the itr block and ur good to go..
what kind of work would have to be done
</TD></TR></TABLE>what kind of work would have to be done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 »</TD></TR><TR><TD CLASS="quote">well youd have to have the bearings sized properly due to the spun bearing....but the save in oil plumbing to the head & also the benefit of oil squirters will also aid in being boosted...plus 300 canadian is pretty cheap...plus about 200 in machine work & you have yourself a decent block for cheap money...</TD></TR></TABLE>
I thought that when you put an LS crank/rods in a B18C you loose the oil squirters cause the crank or rods would hit them. That's just something I read on here, but does anyone know if this is true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">Yes put the LS crank and rods in the ITR block then now you don't need to run extra line for VTEC head and such. I have GSR block with LS crank and rods in it
the gsr block w/ ls crank, is that the GT42(or 40? i forget) setup?
</TD></TR></TABLE>the gsr block w/ ls crank, is that the GT42(or 40? i forget) setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">
I thought that when you put an LS crank/rods in a B18C you loose the oil squirters cause the crank or rods would hit them. That's just something I read on here, but does anyone know if this is true?</TD></TR></TABLE>
With forged pistons you can get rid of the oil squirters, they are not needed! Get some of these to plug the holes for them https://honda-tech.com/zerothread?id=1081578
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila »</TD></TR><TR><TD CLASS="quote">
the gsr block w/ ls crank, is that the GT42(or 40? i forget) setup?</TD></TR></TABLE>
GT4088R set up sir
Edit
lus it is a Hype ARRRRR, errr I mean Type R so get some stickers and make 50whp more too!
GT4088R set up sir
Edit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">I thought that when you put an LS crank/rods in a B18C you loose the oil squirters cause the crank or rods would hit them. That's just something I read on here, but does anyone know if this is true?</TD></TR></TABLE>
i read that too...the weights on the crank hit...almost positive....
With forged pistons you can get rid of the oil squirters, they are not needed! Get some of these to plug the holes for them https://honda-tech.com/zerothread?id=1081578</TD></TR></TABLE>
Are there oil squirter clearance issues with the LS crank/rods in a B18C though?
Are there oil squirter clearance issues with the LS crank/rods in a B18C though?</TD></TR></TABLE>
yea its actually the piston that hits.... the gsr crank is 87.2mm stroke the Ls is 89mm however the LS has 1mm shorter rods ...so the ls crank will pull the piston down 1mm more on each cylinder and smack the oil squirters....some people bend them out of the way but they should jsut be removed.....
Ls rods have the pin hole that sprays oil instead of having squirters.....The ls rod bearings are also different ...they are wider then gsr rod bearings...main bearings will be the same and you will have the girdle for additional high rpm support that hte b16 and LS blocks dont have
Topdawgg
Jan 5, 2006 06:32 PM
