ITR or LS distributor?
Old Dec 19, 2005 | 05:28 PM
greenDC2's Avatar
Default ITR or LS distributor?
I recently replaced my distributor with an aftermarket distributor from distributor king, and it turns out that they sent me a TD44U which is designed for a 92-95 integra non-vtec. I noticed the difference when I tried to put my factory cap on it, is this going to be detremental at all to the perfomance of my motor?? I put it on and it seems to run fine for now, does anyone know if I should be concerned?
Old Dec 19, 2005 | 05:54 PM
RPRacing's Avatar
well, they are the exact same when it comers to internals and functions.
2 questions:
-did it bolt right on or did you saw a leg off the dizzy?
-If you are obd2, did you have to repin your connector?
Old Dec 19, 2005 | 06:25 PM
greenDC2's Avatar
Default Re: (RPRacing)
No it bolted right up, I'm obd1, all the plugs matched up fine, no problems with mounting it.
Old Dec 19, 2005 | 07:39 PM
RPRacing's Avatar
well if it bolted right up, its for a vtec car. the LS head has different hole positions
you have nothing to worry about
Old Dec 19, 2005 | 07:51 PM
greenDC2's Avatar
Yea thats what I'm confused about, i thought the ls only had two bolting points. But the factory cap doesn't fit, so i don't know what the hell I have.
Old Dec 19, 2005 | 07:54 PM
Chris F's Avatar
Default Re: (greenDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Yea thats what I'm confused about, i thought the ls only had two bolting points. But the factory cap doesn't fit, so i don't know what the hell I have. </TD></TR></TABLE>
Whoa, now I'm confused!
Old Dec 19, 2005 | 09:01 PM
RPRacing's Avatar
did you buy your R brand new (being as this is in the ITR forum even though you said your car is obd1...)
You probly just had a b16 dizzy on there before and now you have a gsr dizzy. cap and case are different, but everything else is the same
Old Dec 19, 2005 | 09:57 PM
greenDC2's Avatar
Oh no sorry, I have a 94 gsr with an itr head that came with an itr distributor (I guess), but everything bolts up fine. My old Honda cap won't fit this new one though which makes me wonder what the hell I have. It does bolt up and run just fine. But if this is a non vtec distributor would it be detremental to anything??
Old Dec 20, 2005 | 05:36 AM
RPRacing's Avatar
its a vtec dizzy.everything is fine
Old Dec 20, 2005 | 05:55 AM
greenDC2's Avatar
cool, I appreciate it man
Old Dec 21, 2005 | 07:00 PM
MightyMouseTech's Avatar
It won't be an ITR dizzy, they were all OBDII, your car is OBDI. Who knows what the hell you had. And no, not all OBDI B-series VTEC dizzy's are the same. I use a 94 Integra GS-R dizzy on my race car, quite different than any other OBDI dizzy.
Old Dec 21, 2005 | 07:10 PM
RPRacing's Avatar
Default Re: (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote"> And no, not all OBDI B-series VTEC dizzy's are the same. I use a 94 Integra GS-R dizzy on my race car, quite different than any other OBDI dizzy.</TD></TR></TABLE>
want to explain that one? what are the differences? what are the benefits? what is wrong with the others?
Old Dec 21, 2005 | 07:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing &raquo;</TD></TR><TR><TD CLASS="quote">
want to explain that one? what are the differences? what are the benefits? what is wrong with the others?</TD></TR></TABLE>
The entire housing is a little larger and the cap is a different shape, which pushes the four wire terminals a little further apart from each other. Supposed to reduce spark scatter at higher RPM's. That is the obvious differences, not sure about other internal differences. Will have to check if the coil is different and if the CKP sensor has the same number of teeth on it.
My car (EG hatch with B18C) came with a 93 GSR dizzy, it ran much better at high RPM after I switched to the 94 GSR dizzy. Which sucks because the 94 dizzy is prob the most damn expensive dizzy I have ever bought. I only use OEM.
Old Dec 22, 2005 | 07:11 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Yea thats what I'm confused about, i thought the ls only had two bolting points. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing &raquo;</TD></TR><TR><TD CLASS="quote">well if it bolted right up, its for a vtec car. the LS head has different hole positions</TD></TR></TABLE>
Where do you guys get this **** from?
Its uh... wrong.
Old Dec 22, 2005 | 07:22 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenDC2 &raquo;</TD></TR><TR><TD CLASS="quote">No it bolted right up, I'm obd1, all the plugs matched up fine, no problems with mounting it.</TD></TR></TABLE>
if it bolted up then it is NOT a NON VTEC dizzy.....a non vtec dizzy will NOT bolt up to a vtec head and visa versa!!
Old Dec 22, 2005 | 10:16 AM
RPRacing's Avatar
My car (EG hatch with B18C) came with a 93 GSR dizzy, it ran much better at high RPM after I switched to the 94 GSR dizzy. Which sucks because the 94 dizzy is prob the most damn expensive dizzy I have ever bought. I only use OEM.</TD></TR></TABLE>
didnt know that. thanks
Old Dec 22, 2005 | 10:17 AM
RPRacing's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
cut a leg off the ls and it will work on the vtec though
6doorsentra
May 30, 2006 07:12 PM
Fastwhip
Apr 11, 2006 12:58 PM
I 8 1 U 8 1 2
Sep 18, 2003 02:03 PM
