Alternative(s) to the cheap made OEM plastic screws??
Old Dec 19, 2005 | 03:24 PM
Fuster_Cluck's Avatar
Default Alternative(s) to the cheap made OEM plastic screws??
Detailing my EG today (removed side skirts & complete front support) and need to replace a few of the plastic screws...
These are from the sideskirts. Only a couple would actually screw out to remove. I had to force the rest by pulling the sideskirt out because they would twist but not back out
Mainly need the screws and I believe just one white plastic clip is messed up....
No big deal if I have to buy from Honda. Just want to check because there may be better made universal ones out there.... If you have a parts # that would be perfect from Pep Boys, Auto Zone, etc..... I'm not interested in going out and hunting for these but will go get them if someone has input.
Old Dec 19, 2005 | 03:31 PM
Silverhatch's Avatar
Default Re: Alternative(s) to the cheap made OEM plastic screws?? (Hybrid93Hatch)
the plastic screws ( pops) that hold the fron bumber and rear bumper on are like $$ at a dealership. I brought some and spend like 70 dollars on 2 packets of them
Archidictus's Avatar
Unceasing Measure
You can use any universal clips that fit those holes. You can get large packages of them at Autozone for cheaper than you can get an indivudal one at Honda.
Old Dec 19, 2005 | 03:35 PM
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">You can use any universal clips that fit those holes. You can get large packages of them at Autozone for cheaper than you can get an indivudal one at Honda.</TD></TR></TABLE>
Yeah, I was hoping to get a parts number for them because with my luck (past experiences) I will buy the wrong ones
Old Dec 19, 2005 | 06:19 PM
Royal_C!ty's Avatar
Default Re: (Hybrid93Hatch)
Bump ... cause i need some of those white sideskirt clips as well.
Old Dec 19, 2005 | 06:22 PM
gsr dood's Avatar
Default Re: (eg8kid)
go to autozone...thy hve a whole selection of universal clips, very similar to honda...check it out
Old Dec 19, 2005 | 07:03 PM
Default Re: (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">go to autozone...thy hve a whole selection of universal clips, very similar to honda...check it out</TD></TR></TABLE>
There's an autozone 6 miles from the house.....
I sure hope these clips work better than the OEM ones
I will post pics of the fastners when I get home tomorrow.
Old Dec 20, 2005 | 09:00 AM
I'm about to go check autozone out (King Kong showing at 3:40)
...also got to get replacement bumper to fender plastic connectors
These things blow:
Old Dec 20, 2005 | 09:03 AM
EJ1 wilcox's Avatar
If you have a Lowes nearby go there
They have an assortment of all kind of clips, tabs, everything.
I just picked up some yesterday to use when I reinstall my mudflaps because I destroyed the stockers when I was taking them off.
Old Dec 21, 2005 | 12:29 AM
Do_Ster's Avatar
you might wanna try using toyota plastic screws, no lie haha they fit like honda ones but they are easier to remove (i.e. your not gonna break them taking them off) the thread on the plastic screw is different than hondas
Old Dec 21, 2005 | 02:43 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (Do_Ster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I will post pics of the fastners when I get home tomorrow.</TD></TR></TABLE>
:Sweating in anticipation:
Old Dec 21, 2005 | 05:52 AM
mwieczorek43's Avatar
Default Re: (litterbox)
Just put use some nuts/bolts for your bumper. Or i've seen alot of people use zip-ties.
Why pay Honda a ****-ton for some silly little clip?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">...also got to get replacement bumper to fender plastic connectors
Old Dec 21, 2005 | 06:49 AM
mrbigg9032's Avatar
Try going to a junkyard and tell the guy u just need a few clips, give him like $10 and rape the car of every clip so u have spares for next time. Damn u take your side skirts off when u clean your car, definalty a full detail.
Old Dec 21, 2005 | 06:55 AM
Everyones Hero's Avatar
Default Re: (mwieczorek43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">Just put use some nuts/bolts for your bumper. Or i've seen alot of people use zip-ties.
Why pay Honda a ****-ton for some silly little clip?</TD></TR></TABLE>
That's what I did. I got sick of those silly ******* clips that leave a gap in the bumper so I took some spare bolts I had, put a washer on each side, and bolted it up.
And yes, I've used zip ties. They work, but unless you have heavy-duty ones or a lot of them they will eventually break.
Old Dec 21, 2005 | 01:38 PM
importdreamer's Avatar
Default Re: (Everyones Hero)
Are those the same ones that hold the carpet in in your trunk and stuff? I broke all mine cuz I was a lazy ***.
Old Dec 21, 2005 | 04:02 PM
T.J.'s Avatar
Default Re: (importdreamer)
I've picked up some At Auto zone before in the section that has all the the little HELP packages. They weren't a perfect match to my OEM one's but they worked.
=honda4life=
Honda Civic (2006 - 2015)
Aug 8, 2009 01:57 PM
GetawayInMoscow
10
Dec 9, 2005 02:51 AM
excel88
Jun 21, 2004 05:47 PM
slvrcivic97
Jul 15, 2003 09:10 PM
SwiftTypeR
Jan 24, 2002 06:10 AM
