00 type R swap in ek smog question in ca NEED HELP!!!!
Old Dec 19, 2005 | 01:19 PM
CHAMPwhteEK's Avatar
Default 00 type R swap in ek smog question in ca NEED HELP!!!!
I have a 99 hatchback with a 00 usdm type R swap just got a diagnostic check and no leaks no nothing car runs good.. Mods are intake and a chipped ecu(I think so cause I have no red line) any ways my question is how do I get it too pass smog will it even pass smog... And what steps do I have too go through in order too do this I live in nor cal so if any one can tell me where too go it would be a great help
Old Dec 19, 2005 | 02:17 PM
teamvirus's Avatar
My car breaks a lot!
Default Re: 00 type R swap in ek smog question in ca NEED HELP!!!! (CHAMPwhteEK)
first off you need to put a stock ecu in befor you smog
Old Dec 19, 2005 | 02:20 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHAMPwhteEK &raquo;</TD></TR><TR><TD CLASS="quote">I have a 99 hatchback with a 00 usdm type R swap just got a diagnostic check and no leaks no nothing car runs good.. Mods are intake and a chipped ecu(I think so cause I have no red line) any ways my question is how do I get it too pass smog will it even pass smog... And what steps do I have too go through in order too do this I live in nor cal so if any one can tell me where too go it would be a great help</TD></TR></TABLE>
Put the stock ecu in, make sure all mods have carb numbers and go test. hit up the ref on natomas. when you call to make appointment, they will tell you how to get there.
Old Dec 19, 2005 | 04:43 PM
Default Re: 00 type R swap in ek smog question in ca NEED HELP!!!! (Hybrid93Eg)
Well what exact ecu do I need and who is selling one and around how much am I looking at spending... I stay in sacramento... Also can anyone give me the number too the reff.also if I put the stock ecu back inx should I be able too pass..also what does the reff exactly do that's different from a regular smog check thatnks
Old Dec 19, 2005 | 04:51 PM
EJ8VTEC's Avatar
Mr. Indecisive
also anything else, also try a phone book, also search a little, also also also
Old Dec 19, 2005 | 04:52 PM
vancoland's Avatar
dude...you need to search...i just did and there was like 18 fs threads for a type r ecu, which is the p73. And yes, you should be able to pass smog with the stock ecu because its a newer motor than the car.
Old Dec 19, 2005 | 06:55 PM
Default Re: (vancoland)
Will a 98 ecu off of a type r work cause I got a guy who wants too sell me his for 100
Old Dec 19, 2005 | 07:03 PM
Default Re: (CHAMPwhteEK)
Also do I need a jumper for it or not
Old Dec 19, 2005 | 07:24 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHAMPwhteEK &raquo;</TD></TR><TR><TD CLASS="quote">Also do I need a jumper for it or not</TD></TR></TABLE>
huh?
Old Dec 26, 2005 | 12:22 PM
TEST ONLY's Avatar
dmefb18
Sep 26, 2006 01:00 PM
kDA
Aug 9, 2006 10:16 AM
Achenar
Aug 6, 2004 08:04 PM
SocalChris
10
Jul 15, 2004 11:40 PM
wizzards581
Jul 19, 2003 12:22 PM
