low idle after warmup
Old Dec 19, 2005 | 11:47 AM
byohnd's Avatar
Default low idle after warmup
ok this has been going on for sometime now. 99 civic dx..after the car warms up, it likes to idle down to about 500 rpm maybe lower. when it does this the a/f gauge shows really lean. i was thinking maybe the fpr was bad or something. but i just put a y8 manifold on, new fpr,all new vac lines and it still does it..any ideas?
Old Dec 19, 2005 | 04:16 PM
JDM EK20's Avatar
try checking your idle sensor
Old Dec 20, 2005 | 03:26 AM
byohnd's Avatar
where is that at?
Old Dec 20, 2005 | 03:38 AM
Lonely's Avatar
Default Re: (byohnd)
FITV
Old Dec 20, 2005 | 03:43 AM
The_Todd's Avatar
Farts in the shower
Default Re: low idle after warmup (byohnd)
Adjust the idle near the throttle body.
a/f gauge = light show IMHO
Old Dec 20, 2005 | 06:56 AM
byohnd's Avatar
the a/f is a wb
Old Dec 20, 2005 | 06:57 AM
byohnd's Avatar
also, it is only after driving it. if you start it up and let it sit, it is ok. but if you go for a drive around town, when you go and stop, the idle goes real low.
Old Jan 12, 2006 | 02:14 PM
Vera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byohnd &raquo;</TD></TR><TR><TD CLASS="quote">also, it is only after driving it. if you start it up and let it sit, it is ok. but if you go for a drive around town, when you go and stop, the idle goes real low.</TD></TR></TABLE>
mine seems to do this ... after it warms up , i drive it around and when i come to a stop instead of idleing at 750 . i get about 670 to 700 .. but if i turn my headlights on it brings the idle back up to 750 ... any clues ? heh ben going on for a while
Old Jan 12, 2006 | 02:33 PM
Vera's Avatar
Default Re: (XhaloZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XhaloZ &raquo;</TD></TR><TR><TD CLASS="quote">Well your headlights take more electricity so your car has to rev higher to keep up with the new current load.... as for the idling I bought some cheap *** spark plugs couple days ago and my idle has went down half an rpm but I changed them to Denso and it became normal again... and does it bother you that it idles lower?? It uses less gas lol</TD></TR></TABLE>
yes it does bother me cause it means its not running as it should. hah maybe the engine is compensating for the low idle by using more gas to try to bring it up since it doesnt know what its doing ? or since the idle is lower it is bringing in less air but maybe the injectors are still some how firiing at what they would for normal idle causeing a rich mixture ? i wished my car used less gas hah only get aorund 240 on a stock gsr
99d-series
May 18, 2009 04:51 PM
blkrex
Jan 11, 2007 02:22 PM
redED9Si
Aug 21, 2005 06:58 PM
kb158
18
Jul 30, 2004 02:43 PM
quik2kSi
Dec 27, 2003 09:04 AM
