wtf car wont stay on
ok i just swapped in a d16z6 in my hatch and it was starting but when i revved it, it would shut off. now the car would start and then shut off in like 2 seconds and there were no cel's. tried 2 distributors and 2 other ecu's and same thing.
It sounds like maybe the fuel pump isn't getting sufficient pressure, however you engine has to be on for a few seconds to get a CEL. If it only runs for 3 seconds, there's a good chance it won't throw a code, even if there is one. Are your sensors mix-matched? IE: Map sensor and TPS sensor switched.
ok fixed the prblem turns out fuel pressure was low like 0 rly said. now when i rev it its bogging really bad and i have to mash the gas pedal to start it like a carburator car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish »</TD></TR><TR><TD CLASS="quote">it sounds like it could be your idle air control valve. defintly no your main relay cus the car wouldnt even crank </TD></TR></TABLE>
if it was the iacv wouldn't it throw a code?
dubzz24
Mar 2, 2007 09:14 AM
Morning Call
Jul 19, 2006 03:14 PM
Jimmy
Jul 10, 2003 08:52 AM
