piston to head clearance ??????
Old Mar 17, 2002 | 05:16 AM
jt-sport's Avatar
Default piston to head clearance ??????
how much we can give the minimum piston to head clearance for D Serries engine that using Custom Rods and rev arround 9000 rpm ???
Old Mar 17, 2002 | 06:22 AM
integster's Avatar
Default Re: piston to head clearance ?????? (jt-sport)
Run a thicker head gasket..You can get custom rods but im not sure that it would be worth it ..Why do you want to mill your head ????
leeo
Old Mar 17, 2002 | 08:29 AM
rainforest's Avatar
Default Re: piston to head clearance ?????? (integster)
clay check the moter and you will really know whats going on.
Old Mar 17, 2002 | 08:34 PM
jt-sport's Avatar
Default Re: piston to head clearance ?????? (rainforest)
Im sorry if my grammar was worst (and i dont understand with "clay check" mean )
yes to upping the compression ratio. (by using the more thin head gasket)
i've use JE pistons that have huge and deep reliefs ,so im not affraid the valve will hit the pistons.
The point im affraid is ,at high rev (arround 9000 rpm plus) , the conecting rods will "outstretched" (even it was Custom Rods) and thrown the pistons hitting the head.
How thin (the head gasket) the space between the pistons and head we could give to the engine??
Im sorry if my english was bad ,and always make some miss communication before
Thanks
MalcolmV8
May 18, 2012 03:19 PM
JaiDM
15
Apr 4, 2003 04:19 PM
GummiBeer
17
Mar 9, 2003 09:30 PM
turboex
Nov 11, 2002 11:43 AM
