Y8 oil pan fit on a Y7? yes or no and why? **SEARCHED**
exactly what the title says. just need to know if they work.
im almost positive i know the answer, but i cant be sure
Brett
Brett
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skynet »</TD></TR><TR><TD CLASS="quote">y8 oil pan install on a y7 yes
y7 oil pan install on a y8 no</TD></TR></TABLE>
explain, as if one goes on the other with no problems, vice versa should hold true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaniceday »</TD></TR><TR><TD CLASS="quote">i went to https://www.hondaautomotiveparts.com and the part #s are different ..
NO ****. maybe cause one is aluminum and one is steel. one is about 100 bucks and the other is about 300.
I KNOW THEY ARE DIFFERENT. i just want to know if the y8 pan will fit on a y7. thats all i want to know. i dont car about the z6, the a6, or the b7, i want to know DOES ANYONE HAVE A Y8 OIL PAN ON THEIR Y7??
and please dont post if you have no idea what youre talking about
Brett
</TD></TR></TABLE>NO ****. maybe cause one is aluminum and one is steel. one is about 100 bucks and the other is about 300.
Brett
yea the oil pan off a y8 will fit the y7 for me i had to switch them because the y7 i got was a auto and the oil pans are different from man to auto so i swapped them. So yes it will fit just bolt it up EASY!!!!
um, no. my old y7 was from an auto. i put a manual tranny on it and didnt change the oil pan.
Brett
Brett
The VTEC oil pans might be deeper and/or the oil pickup might hang lower, thus necessitating a deeper oil pan. Keep VTEC pans on VTEC motors and vice-versa.
yes, it works. BUT only if you use y8 oil pan. So rule is: y7, y7 gasket. y8, y8 gasket. hope everything turns out well for you! 8)
I had a Y8 oilpan on my Y7. it fit with the Y7 gasket. It is deeper/taller so it interferred with my downpipe. You should be OK if you are NA.
oh trust me, i know what they look like, i know they use a TOTALLY i different gasket (the y8 seals SOOOO much better). i just wante to be sure they would bolt up no problem. thats good. im satisfied now. ok then, i can sell my tapped y8 pan to the guy with the Y7 block, lol
Brett
Brett
boostincoupe
Feb 2, 2006 12:56 PM
