1994 Civic Sedan EX Master Cylindar leakage. I've a few questions.
Old Dec 18, 2005 | 01:08 PM
1995Ex_Sedan's Avatar
Default 1995 Civic Sedan EX Master Cylinder leakage. I've a few questions.
Okay. So I noticed while driving there at times, there is a VERY slight fade in the brake pedal. It does NOT go to the floor, just it will give a very small amount when held or pressed hard. I can release and let it back up, step on it again ands its fine. I asked our techs and was told that the seals are probably old and its leaking slightly, he said its sort of a common thing with hondas. I also noticed like a sort of leak beneath it too. So, what are your guys's ideas? Is this easy to fix? I'd love to do it myself, to save the labor charge. Does the whole thing need to go? or just the seals hes talking about.
I'm off to do some searching on this subject.
Thanks in advance.
I should also add shes got 210k on her, and I don't know when the MC or the seals were last checked.
Modified by 1995Ex_Sedan at 5:50 PM 12/19/2005
Old Dec 18, 2005 | 02:03 PM
six_speed's Avatar
just buy a replcement at an auto store ie..autozone/kragen/pepboys. the seals are inside the break master cylinder.
tools needed
10mm flare wrench
12mm wrench
needle nose plier
break fluid
Old Dec 18, 2005 | 02:04 PM
Targa250R's Avatar
be professional
Default Re: 1994 Civic Sedan EX Master Cylinder leakage. I've a few questions. (1995Ex_Sedan)
You'll also need a bleeder monkey to help you bleed the lines
Old Dec 18, 2005 | 03:37 PM
Thanks Alot.
Old Dec 18, 2005 | 07:43 PM
hatchi's Avatar
Default Re: (1995Ex_Sedan)
they sell rebuild kits but dont buy it because you will have the same problems again. Just buy a new one.
Old Dec 19, 2005 | 02:53 PM
Rebuild kits? Money is kind of tight at the moment, I might just look into that for a temp fix.
Old Dec 19, 2005 | 03:46 PM
Okay, I had a closer look when I had the time, and there is like a film of brakefluid, like old leakage where the master cylinder bolts to the brake booster. Today the pedal was slightly worse, going to the floor in about 5-6 seconds after braking, I'd let it up and it'd be firm again, then about 10 seconds later, be at the floor. Its okay during normal driving, just sitting holding the brakes, it sinks.
Old Dec 19, 2005 | 04:55 PM
Targa250R's Avatar
be professional
Yep, that MC is on its last legs.
Old Dec 19, 2005 | 05:45 PM
Thankyou, Rebuild kit it is.
Old Dec 19, 2005 | 05:46 PM
93civicsedan's Avatar
Default Re: (Targa250R)
Id get that fix asap, you dont want to press the brake pedal one day and not have the car stop at all. I have a stock lx master cylinder i could sell you, pm me if interested.
Old Dec 19, 2005 | 06:29 PM
Thanks, but I've got the resources here, close to home. Thanks though!
Jianshatch
Feb 21, 2017 11:08 AM
oskar_0709
Jul 17, 2012 02:20 PM
excivicboy96
Sep 13, 2007 06:54 PM
JokerTypeR
Jul 25, 2006 12:03 PM
raynaud
Aug 1, 2004 01:52 PM
