taking off timing belt cover...
this is on a d-series by the way... i've taking out 2 bolts that i can see which seem to be holding the cover on (the top portion) but it's not comming loose?
This is hard to say without seeing which bolts you took out, but I do know that the valvecover must be removed.
Also, one has to wonder...if you're having trouble getting the top part of the timing cover off, should you really be messing with a timing belt on an interference motor?
rice h8r
Jul 15, 2011 09:32 PM
Tippyman
Feb 18, 2006 10:03 AM
