Integra shifter in my EF?
Can I fit an integra shifter in my EF? I'm pretty sure I have the modified SOHC shift linkage (its got the threads). I like the bend the integra one has and I coulda sworn I seen it before somewhere else...
Thanks!
Thanks!
hey dude, the DA or 90-93 teg is the same shifter
the 94-00 shifter requires some creativity to fit, but it can go in...i have one on my EF and it seems like a shorter throw than the stock EF unit, and nowhere near as notchy as a short throw shifter....you have 2 options to get it there, extend the connection on the linkage or grind the shifter down to fit in the smaller space, but i have a rattling sound coming from mine cause that plastic bearing melted while grinding....so its up to you dude....good luck
all you have to do is cut the sides of it to make it fit (dremel), but i have a hcp adjustable shift linkage so i don't know how it would be on a modified shift linkage (welded one) but it's great if your tall becasue mine sits a little farther back but it sits straight and feels like stock!!!
jsanchezeEf91
Oct 30, 2013 08:12 AM
