crx engine help!
the car wont start and i'm getting code 6 (coolant temp sensor), 10(air intake temp sensor), 13(atmospheric pressure sensor),and 20(electric load detector) from my ecu. I'm guessing something's really messed up with my car. does anyone know wtf is going on here?
i believe all of those are in the smaller of the two connectors by the fuse box, jigge the connectors maybe they are not in all the way, i had the same problem after my swap, i had to just push the connectors together real hard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 »</TD></TR><TR><TD CLASS="quote">how can u read codes?!</TD></TR></TABLE>
There's a light on the ecu..turn the key to the on position and count the blinks at the ecu..Short blinks = 1 ..And if it stays on for a while it = 10..For example one long blink and 2 short ones = code 12.. three shorts blinks = code 3..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 »</TD></TR><TR><TD CLASS="quote">but how can i do that!?</TD></TR></TABLE>
Pull the carpet back and you'll see the ecu..
red91g2
Aug 7, 2005 08:20 PM
