Main Relay Flipping Out
Old Dec 17, 2005 | 09:24 AM
93supercoupe's Avatar
Default Main Relay Flipping Out
So i got my Uber chips to burn after like 3 weeks of no managment.lol.
So when i got put the chipped ecu in the car (90 Civic STD.), the main relay starts clicking "like a machine gun".
But when i warm the car up with another stock ECU and then switch to the chipped ECU it will run.And itll run perfect.
Im just wondering if the IAT adjustment has something to do with the cold starts.
Or maybe my relay is half bad or sometrhing.
Im using Uber 1.7Repack.
Its a D16y8
Help me out here
Old Dec 17, 2005 | 10:26 AM
Default Re: Main Relay Flipping Out (93supercoupe)
now the car wont start wioth the Uber ECU and warm.
IM going to change out the main relay now and see if that has something to do with it.
Old Dec 17, 2005 | 10:32 AM
vietjdmboi's Avatar
usually when a relay clicks like crazy means that there is a problem with the ground. get a wiring diagram and look for the ecu ground. that might be the problem. look and see if it is diconnected or not fully tightened
Old Dec 17, 2005 | 10:57 AM
2point2's Avatar
The ground on your thermostat is loose. clean, tighten, enjoy.
Old Dec 20, 2005 | 03:57 PM
Default Re: (2point2)
Ill give it a try.Thats the most direct answer Ive seen on H-T in a while, thanks.
Old Dec 20, 2005 | 04:03 PM
turbotime's Avatar
**** i may have the same problem! does the clicking increase and decrease with rpms?
Old Dec 20, 2005 | 04:11 PM
D@nnY's Avatar
Default Re: (turbotime)
thats from the ecu /soldering/and or program
Old Dec 20, 2005 | 04:13 PM
No, it doesnt run on the chipped ECU at all anymore.But with a stock ECU the relay is fine and the car runs perfect.
I got it to run once on Uber but forgot to elimnate my speed limiter and O2 so I took it out to reburn and it never ran since and i didnt touch anyhting else except the ECU plugs.
my car is now running on stock ECU.
Old Dec 20, 2005 | 04:15 PM
turbotime's Avatar
Default Re: (D@nnY)
I think mine might just be my injectors (450dsm) but then i was wondering if it was a bad ground and my main relay... i am also experiencing other bad ground symptoms (crazy speedo/tach, apexi turbotimer goes from reading a/f to not reading a/f even tho there is still good o2 voltage)
sorry, dont mean to thread hijack
Old Dec 20, 2005 | 04:18 PM
Default Re: (93supercoupe)
The smae chipped ECU was running my LS/Vtec JRSC in the same car.
It ran perfect when I took it out.
Now with my D16Y8, it wont run the car.
I changed my relay and it did nothing, so dont waste ur time, lol.
Old Dec 20, 2005 | 04:21 PM
turbotime's Avatar
damn good luck man, yeah i think i have a bad ground, started a thread..
DDTECH
May 11, 2012 08:42 PM
white90rexsi
10
Jun 28, 2007 02:50 PM
itr1244
Jun 23, 2006 05:57 PM
5genhatch
Aug 7, 2005 01:15 PM
