Car wont start....click click
Old Dec 17, 2005 | 07:55 AM
vtec69's Avatar
Default Car wont start....click click
So i was at my friends house and after my car sat there for like 3 hours i went to start it and I just got a clickin noise.
So I tryed to jump it and got nothing but a clicking noise when cranking
So than the next day i went over and turned the igniton on and off very fast and ended up starting.
So I drove home and a block from my house I lost all the power and the lights went off.
So I pulled over and wiggled the ground on the battery and the lights went back on.
Went to go start the car again and just got a clicking noise again
I tried hitting the starter with a hammer and still nothing.
Someone please help my car is stuck on the side of the rode and i dont know what i should do
Thanks
-Brian
Old Dec 17, 2005 | 08:01 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Car wont start....click click (vtec69)
Replace the starter. I've seen them go on more than one occassion.
Edit: Nevermind I just caught the battery part. Sounds like a loose terminal. I would replace the battery terminals on the positive and negative sides.
Old Dec 17, 2005 | 08:02 AM
vtec69's Avatar
Default Re: Car wont start....click click (JDM_Ej)
yeah thats what i was thinking but its stuck on the side of the road and cant get the car home...
Old Dec 17, 2005 | 08:05 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Could be the battery terminals themselfs too.
Old Dec 17, 2005 | 08:08 AM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Could be the battery terminals themselfs too.</TD></TR></TABLE>
and im hopeing thats what it is, cause it was wierd, i would wiggle the negative battery termnal and i got the power back, but i know have the power back and still no start.
I really hate cars
PS:its not a honda but this is the only place I can get good replys from
thanks
Old Dec 17, 2005 | 08:14 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">and im hopeing thats what it is, cause it was wierd, i would wiggle the negative battery termnal and i got the power back, but i know have the power back and still no start.
I really hate cars
thanks</TD></TR></TABLE>
That has to be the problem. Make sure they are tight first, if its still a problem replace the terminals. Could try and replace the battery too.
Old Dec 17, 2005 | 08:19 AM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">That has to be the problem. Make sure they are tight first, if its still a problem replace the terminals. Could try and replace the battery too.</TD></TR></TABLE>
the battery was actually just replaced like 1 month ago so i kinda ruled that out as a problem
Old Dec 17, 2005 | 08:52 AM
Slopoke's Avatar
Try cleaning your terminals, before you go replacing them.
Old Dec 17, 2005 | 08:54 AM
jadugartir's Avatar
check for corrosion on both the battery ground and the wire to the starter. I assume your terminals arent corroded either because that one would be obvious. If all wiring checks out ok, then replace your starter.
Old Dec 17, 2005 | 09:18 AM
vtec69's Avatar
Default Re: Car wont start....click click (jadugartir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadugartir &raquo;</TD></TR><TR><TD CLASS="quote">check for corrosion on both the battery ground and the wire to the starter. I assume your terminals arent corroded either because that one would be obvious. If all wiring checks out ok, then replace your starter.</TD></TR></TABLE>
Just went to the car and took off the neg terminal and it looked good at both ends so i tightened it up and still nothing
then i looked at the postive terminal and it looked a lil bit melted(its a side terminal battery) so i went to tighten it and it was loose.
Tightened it up and the car started right up
So releaved cause this car is a bitch to change the starter, have to take off the header or remove part of the subframe and its cold as hell out so im so realeaved
Thanks everyone for your help
Old Dec 17, 2005 | 09:58 AM
Archidictus's Avatar
Unceasing Measure
Clicking when you turn the key = not enough juice to turn the starter - either from a poor connection or bad battery.
"Zooming whine" when you turn the key = bad starter solenoid/nose cone.
Nothing when you turn the key = no power whatsoever and/or starter wired incorrectly.
These are simple ways to deduce starter failure. How do you have over 10,000 posts and you can't tell when your battery terminals are loose?
Old Dec 17, 2005 | 10:01 AM
vtec69's Avatar
Default Re: Car wont start....click click (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
These are simple ways to deduce starter failure. How do you have over 10,000 posts and you can't tell when your battery terminals are loose?</TD></TR></TABLE>
haha
yeah this isnt a honda and when it comes to another car besides a honda i somehow get stupid for some reason
and also im not used to the side terminal batteries too
Old Dec 17, 2005 | 10:17 AM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">haha
and also im not used to the side terminal batteries too </TD></TR></TABLE>
I actually had the same thing happen on a Cadillac once. Side-terminal batteries suck. Thank you, General Motors, for making everything just a little more difficult than it needs to be!
Magsy
Honda Civic (2006 - 2015)
Jan 23, 2018 10:47 AM
JSpekBB4
Apr 3, 2006 02:46 PM
Mjfan12
Oct 1, 2004 03:00 PM
92DSeries
May 1, 2004 12:09 PM
UnionCity LS
Feb 5, 2003 07:49 PM
