Engine Swap Help!
Old Dec 16, 2005 | 11:12 PM
guibo's Avatar
Default Engine Swap Help!
I read the archived information about the swaps and searched as well, im still finding it difficult to finish my swap.
I have a 99 dx and a OBD1 B16A waiting to be put in.
i have a friend withn a salvaged EM1, and im using his harness.
i know i can either convert the harness to OBD1, by using the remaining plugs from the motor and using my SOHC injectors.
i have access to all the components from his EM1, such as the distributor, alternator, etc...so i could convert the motor to OBDII.
at this point i dont know which route to take.
what else needs to be done to convert this, and is there an easier way.
if anyone has a wiring diagram or writeup how to do this, it would be greatly appreciated.
any and all information would be greatly appreciated.
(PS, i need this done by the 23rd, so if anyone in the NOVA area wants to make a hundred bucks and kick back a couple beers, shoot me a PM .)
Old Dec 17, 2005 | 06:36 AM
guibo's Avatar
Default Re: Engine Swap Help! (guibo)
bump
Old Dec 17, 2005 | 06:38 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
You can keep it OBDII by using the EM1 harness, distributor and injectors. Then get a jumper harness at the ECU and run an OBD1 ECU.
Old Dec 17, 2005 | 06:00 PM
guibo's Avatar
Default Re: Engine Swap Help! (JDM_Ej)
Is there anything else i would need from the em1 besides dist., and injectors? What about the alternator plugs, they are different.
Old Dec 17, 2005 | 07:09 PM
hatchi's Avatar
you can use his alternator, harness, distributor, injectors. intake manifold if you want.
Old Dec 18, 2005 | 08:37 PM
guibo's Avatar
Default Re: Engine Swap Help! (hatchi)
so basically swap out the obd1 components for the obd2?
Old Dec 19, 2005 | 11:54 AM
guibo's Avatar
little help
Old Dec 19, 2005 | 12:38 PM
EJ8VTEC's Avatar
Mr. Indecisive
u need one more sensor, i cant remember what its called, it counts the revolutions of the oil pump, someone help me out... and just get the 99-00 si ecu, p2t, its obd2 n will plug right up u can use any obd2 injectors, the si or the dx will prob work too
757toad
Aug 14, 2008 03:24 AM
peAches yO
Jun 21, 2007 08:36 PM
g_rant2006
Apr 20, 2006 08:57 AM
Civicman86
Jan 25, 2006 08:43 PM
adnoHCivic
Jul 24, 2005 03:03 AM
