y7 and y8 mini me
Old Dec 16, 2005 | 09:53 PM
Eaglekper0046's Avatar
Default y7 and y8 mini me
I did my mini-me swap a few days ago y7 block y8 head. Everything was good till I changed the injecters. The car is a 2000 hatch, head 96. I know it doesnt matter. I put the y8 injecters in. The car runs good a day or two later I get a cel. Car still runs good. Code p0170, p0172. Im running the dx ecu w/ field vtec controller on stock settings. Any Ideas.
Old Dec 16, 2005 | 10:06 PM
Default Re: y7 and y8 mini me (Eaglekper0046)
The code reader also says bank 1 one is running rich. I dont understand how its only one.
Old Dec 16, 2005 | 10:28 PM
Mwsol's Avatar
what ecu are you running? If your running the y7 then yes you will be rich as the injectors out of the y7 are smaller. Thus, the ecu still thinks to send the same amount of pulse width err whatever to the injectors and causing you to run rich because the pintle size is larger in the y8.
Old Dec 16, 2005 | 10:47 PM
Default Re: y7 and y8 mini me (Mwsol)
What should I do just live the cel? I have a 96 vtec ecu, but I dont want to but the ecu adapter. Since Im boosting my y8 sometime next year. Would the motor be ok with y7 injecters? (obd2 sucks ***)
Old Dec 16, 2005 | 11:00 PM
MNRacer's Avatar
Isn't 2000 still OBD-II just OBD-IIa, If it connects just use the ecu that already has Vtec and it should be find.
Old Dec 17, 2005 | 05:53 AM
Default Re: y7 and y8 mini me (MNRacer)
no th 00 is a obd2b 96-98 is obd2a. so I dont what to do
Old Dec 17, 2005 | 07:11 AM
eg360B's Avatar
buy a OBD1 adapter and get a P28
Old Dec 17, 2005 | 07:15 AM
dohcVTECeg2's Avatar
Default Re: y7 and y8 mini me (Byrd Gang 021)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Byrd Gang 021 &raquo;</TD></TR><TR><TD CLASS="quote">buy a OBD1 adapter and get a P28</TD></TR></TABLE>
this is what you need to do
Old Dec 17, 2005 | 09:57 AM
97spooncivic's Avatar
are you using a p2e ecu? you need a p2p ecu
greenman94
10
Feb 23, 2013 03:04 PM
Ekevans08
Dec 12, 2012 06:11 AM
Nu-Skul Racing
Apr 5, 2009 06:17 PM
NHB
Apr 3, 2007 04:29 AM
EJ8 944
10
Jan 27, 2007 03:51 PM
