pulleys and such
Old Dec 15, 2005 | 09:01 PM
zigzack's Avatar
Default pulleys and such
I've been considering raplacing the pulleys on my '91 accord lx with lighter weight ones, any ideas? I'm also gonna raplace my rotors with Brembo slotted ones, Anybody got any sources for lighter drums? Gotta cut the weight on them rotating parts.
Old Dec 15, 2005 | 09:11 PM
i_kick_turtles's Avatar
Default Re: pulleys and such (zigzack)
Lighter rims would be the thing to do. Drums and rotors won't make a difference.
Here's a writeup on weight reduction for 4th gens:
http://www.cb7tuner.com/vbb/showthread.php?t=10770
Old Dec 15, 2005 | 10:50 PM
voiceinurhead05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zigzack &raquo;</TD></TR><TR><TD CLASS="quote"> Anybody got any sources for lighter drums? </TD></TR></TABLE>
If you plan to add power to your motor (which a lightwieght pulley would do) the brakes need to have enough stoping power to handle it. Drum brakes may work fine when the car is all stock, but if you want your brakes to perform, they should be discs all around. Disc brakes provide better stopping power and are less likely to fail under pressure then drum brakes.
Old Dec 16, 2005 | 05:42 AM
wingback44's Avatar
Default Re: pulleys and such (voiceinurhead05)
i dont think pulleys are going to add enough power to require a brake upgrade. pulleys are probly only going to add about 2-3whp. lighter wheels are the way to go, less rotating mass and and they look good.
Old Dec 16, 2005 | 08:30 AM
P_Adams's Avatar
You're mixing apples and oranges with a few misconceptions.
Recovered power from pulleys is not accomplished because they're lighter, it's because either they're larger in diameter (accessory/under-driven), smaller in diameter (Crank Pulley) and turn the accessories slower (using less power)) or adjustable; as in the camshaft drive sprocket.
Brembo slotted Rotors are a good choice (I use them)
If you can find Aluminum/Steel Liner versions of the rear drums, go for it. Not for the weight reduction but for the better heat dissipation
P
edited for clairfication
Modified by P_Adams at 7:48 PM 12/16/2005
Old Dec 16, 2005 | 11:21 AM
zigzack's Avatar
I R Taylor, reducing weight on any rotating part, unless its like a tiny part is going to help, reducing weight in rotating parts is one of the most important things in weight reduction. When something with weight spins it transfers that weight in every direction, creating more drag on itself and whatever its rotating on or with. And yes I'm going to replace my stock steel rims with aluminum 15's when I have the 8 grand to spend, wanna keep the wheels honda. And in regards to stopping power, I'm not gonna turn this car into a race car, its my every day driver, so i figure upgrading my front brakes like I planned would be enough, and i'm gonna change the brake setup over to acura parts so I can have demountable rotors, for easy changing, might also go with a larger diameter rotor along the way, but i'll have to replace my caliper to do that so it might not be worth it, probably just gonna stick with the slotted rotors.
Old Dec 16, 2005 | 11:23 AM
zigzack's Avatar
Also, I should've specified, I was more asking about parts companies, like a good one to get pulleys from, so far I've found AEM pulleys and Unorthodox racing pulleys, anyone know of others?
Old Dec 16, 2005 | 11:57 AM
zigzack's Avatar
That thread mentions replacing you battery with a lightweight one, and other things, like my carpet for example? So why would you tell me that rotors and drum weight dosn't matter but then refer me to some thread that is saying that taking out my carpet and important things like my gas, and even my spare tire(kinda seems ignorant to take out your spare tire to me).
Old Dec 16, 2005 | 12:08 PM
idewson's Avatar
Default Re: (zigzack)
AEM pulley's are a good choice. I use them and they work out great. If you're looking for more weight reduction. Carbon fiber hood and trunks are a good idea. They are not the rotating parts that you are talking about but that can be decent amount of weight reduction.
Old Dec 16, 2005 | 07:09 PM
The amount of weight you are going to save from slotted rotors and lighter drums is going to be very minute. I would call it a tiny part when you compare a stock rotor to a slotted one, or a stock drum to a lighter drum. I'm not saying don't upgrade, i'm saying upgrade them for braking performance, not weight savings.
This would be a much more substantial savings to the weight of your rotating parts and aluminum rims will cost you nowhere near 8 grand. keep an eye on the classifieds and ebay. BTW: prelude sawblades=19 lbs each.
Stainless steel brake lines and slotted rotors (maybe even legend 2 pot calipers) are great budget ways to upgrade your brakes and usually more than sufficient for a daily driver.
it's called rotor over hub, and a great upgrade. I would post up a diy link but something in there might be "ignorant."
you wouldn't have to replace the calipers, just the brackets.
those two are the best. some people have obx and other ebay ones. the quality on obx is questionable. Whatever you do DON'T get an ebay crank pulley. they won't fit on the crankshaft.
I did not write that thread. It is up to you, the reader, to decide which of those things would be beneficial to you, and which ones you are willing to do. I would agree that some of those things aren't things I would like to do. But you obviously don't know how much your carpet weighs. It is far more than the 1 pound you would save from slotting a rotor, even if the rotor is rotating. Ignorant to take your spare tire out? I don't know if it's ignorant, but it is risky.
I was trying to help, don't be a dick.
Old Dec 17, 2005 | 05:18 AM
DoC-JoneS's Avatar
Default Re: (I R Tylor)
reducing the ammount of rotational mass that the crank has to move is a good way to free up some power and response. i've been looking into the UR underdrive crank pulley for some time now. Cheaper than the AEM kit and it reduces weight where it matters the most, the crank. also it only requires removal of one pulley not three.
93civicjaydm
Honda Civic (2006 - 2015)
17
Apr 23, 2008 09:19 AM
The_Todd
Jun 8, 2005 05:30 PM
civicross
33
Dec 28, 2004 11:04 AM
singlecam screamer
Aug 19, 2004 04:32 PM
typrkiller
Oct 14, 2003 12:43 AM
