lightweight brakes
i'm wondering if aanyone knows where i can get a set of lightweight front brakes,i currently have gsr brakes all around but they added 50lbs to the car so i saw someone post on here maybe like a year ago a set of wilwood brakes for the front any help will be greatly appreciated TIA
the wilwood calipers, the dynalites weigh 2.5 lbs a peice. theire rotors weigh all teh way from 8 lbs up to 18 lbs depends on size, drilled or not etc. u can get rotor weights on thier site http://www.wilwood.com/Products/Rotors/index.asp stock civic rotors are liek 13 lbs each and the calipers are about 8 lbs. so you save lots of unsprung weight with wilwoods. good luck
Charlie Moua
19
Mar 24, 2012 06:18 AM
