will I have any problems using a light flywheel with stock clutch
Old Dec 15, 2005 | 05:27 PM
vtec fan's Avatar
Default will I have any problems using a light flywheel with stock clutch
Hey guys I am currently having a h22 engine swap done (my motor was knocking)
the shop doing the job said that the old h22 (one being swaped out) had a performance clutch and flywheel, but the clutch needs to be replaced they said that if i go back to a stock dealer clutch I will have to change the flywheel back to stock. Is this true? I looked around on the net and all the posts I have seen said that a stock clutch should be able to work with the lightened FW no problem. thanks for your help.
Old Dec 15, 2005 | 07:59 PM
Slopoke's Avatar
Default Re: will I have any problems using a light flywheel with stock clutch (vtec fan)
I currently have a lightweight flywheel with a stock clutch. No problems at all!
I know lots of guys with the same set-up.
tweekerz
Jul 28, 2006 07:43 PM
vtec fan
Dec 17, 2005 02:39 AM
vtec fan
Dec 15, 2005 08:48 PM
