synthetic oil to conventional oil
Old Dec 15, 2005 | 01:31 PM
josephshark's Avatar
Default synthetic oil to conventional oil
The previous owner of my new delsol supposedly used mobil synthetic oil. Would it be ok for me to go back to conventional oil ?
Thanks,
Joe
Old Dec 15, 2005 | 01:33 PM
snatch's Avatar
Default Re: synthetic oil to conventional oil (josephshark)
Miles? A lot of poeple say it's not good to switch back and forth as it's hard on the seals.
It's kind of a matter of preference though, whether or not you believe it will hurt anything and whether you're willing to risk it.
Old Dec 15, 2005 | 05:42 PM
Default Re: synthetic oil to conventional oil (******)
I guess I should take the guys word, and stick with synthetic. Is there any particular synthetic which is not very expensive I should use ?
Old Dec 15, 2005 | 06:37 PM
.Ry's Avatar
.Ry
Stick with Mobil 1 if he had no problems. I swear by that stuff. I suppose you could do a 50/50 of synthetic/conventional and wean down from there.
Old Dec 15, 2005 | 06:41 PM
EG2Driver's Avatar
Default Re: synthetic oil to conventional oil (turner7205)
dont cheap out on ur engine and your engine wont cheap out on you. Keep it synthetic.
Old Dec 15, 2005 | 06:43 PM
sicky's Avatar
grammer nawzi
Default Re: synthetic oil to conventional oil (deadend9009)
motul 8100 5w30 is pretty cheap. . .
Old Dec 16, 2005 | 05:29 AM
Ok, I don't want you guys to think I'm cheap
The thing is, judging by the title, this guy had the car for maybe a year.
There is no way of know whether or not he used synthetic correct ???
I have read that going to syn. after a life of conventional, is just as bad as the other way around.
If I seafoam the motor, could I then go to conventional with out possibly coming up with problems?
Thanks,
Joe
Old Dec 16, 2005 | 05:44 AM
sicky's Avatar
grammer nawzi
why doesn't this thread just stop. put whatever oil you want in the car, I'm sure it's not going to make a difference. it's your car, make your own decision. on honda-tech you are going to just get biased opinions with questions like this.
Old Dec 16, 2005 | 05:56 AM
AutoXer's Avatar
Default Re: synthetic oil to conventional oil (sicky)
You can switch back, you'll be fine. There's no problem with seal compatability on modern engines.
You also don't need synthetic in your car, or to change the oil more than is specified in the manual. I have data to show it, but nobody seems to care about that and just argues back and forth or spewing how they love synthetic.
Old Dec 16, 2005 | 05:57 AM
sockvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">why doesn't this thread just stop. </TD></TR></TABLE>
thread hasnt stopped cause the answer hasn't been given yet...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">Miles? A lot of poeple say it's not good to switch back and forth as it's hard on the seals.
It's kind of a matter of preference though, whether or not you believe it will hurt anything and whether you're willing to risk it.</TD></TR></TABLE>
yes, switching has shown to cause damage on the seals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 &raquo;</TD></TR><TR><TD CLASS="quote">dont cheap out on ur engine and your engine wont cheap out on you. Keep it synthetic.</TD></TR></TABLE>
this has got to be the dumbest thing ive heard all day, and lucky for you its the beginning of the day.
price doesnt always have a positive correlation to quality...and keep it synthetic? synthetic is not always the best...do some research and you will find that out
if the engine has always been on conv. oil then keep it on conv. oil, same for synthetic...like as the dude before me said the best thing to do is ween it because i switched twice (from conv. to syn and then back to conv.) and im leaking oil from bout everywhere i can
Old Dec 16, 2005 | 06:00 AM
sockvtec's Avatar
Default Re: synthetic oil to conventional oil (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">You can switch back, you'll be fine. There's no problem with seal compatability on modern engines.</TD></TR></TABLE>
well he did say new del sol, but i wouldnt necesarly say its a modern engine...and i know for sure my z6 is havin some seal problems cause the switch in oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">You also don't need synthetic in your car, or to change the oil more than is specified in the manual. I have data to show it, but nobody seems to care about that and just argues back and forth or spewing how they love synthetic.</TD></TR></TABLE>
Old Dec 16, 2005 | 06:37 AM
AutoXer's Avatar
Default Re: synthetic oil to conventional oil (sockvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec &raquo;</TD></TR><TR><TD CLASS="quote">
Well, modern as in not carburated and developed after synthetics to be compatable.
What I've seen happen, is when someone uses conventional for a long time, and doesn't maintain the car properly. Somewhere down the road, they decide to use synthetic, which cleans all the sludge from the engine, and could possibly cause leaks.
The leaks would have happened anyway, synthetic just accellerated the process. If your seals are bad, they will eventually leak regardless of what type of oil you use; but the leak gets blamed on the oil anyway.
Old Dec 16, 2005 | 07:18 AM
Targa250R's Avatar
be professional
Well my engine hasn't cheaped out yet after 251,000 miles on conventional oil, so I'd have to say that synthetic is a waste of money.
Old Dec 16, 2005 | 08:34 AM
slwburn's Avatar
Heres your answer - use whatever you want.
You can go back and forth all you want.
http://www.quakerstate.com/pag...w.asp
Old Dec 16, 2005 | 01:53 PM
Default Re: synthetic oil to conventional oil (slwburn)
Thanks All,
Thanks slwburn for the awesome link. I will heed Quakerstates advise.
Joe
Zebra
Honda Civic (2006 - 2015)
Mar 8, 2011 07:55 AM
mike93eh2
Jan 6, 2007 10:06 AM
speedy108
Dec 22, 2004 04:15 PM
Xxcivic99xX
Aug 4, 2004 07:51 AM
Nextelbuddy
Mar 6, 2004 01:36 PM
