93 civic 99b18b heat wont get hottt.. so cold outside
whats up.. last year my heat would accually get hot.. this year it doesnt.. it just gets a little warm but not warm enough to drive around...any suggestions?
the coolant temp works.. sumtimes it will go up and down tho so sumthing might be on its way out.. and the heat doesnt work
Yeah, if its the heater, I would think that the coolant passages might have a lot of junk in them around the heater core, or its just a bad heater core.
You can see where the two coolant lines go to the heater core, as they are the only two coolant lines that go into the firewall, just slightly toward the passenger side from center, of the firewall.
grimview
Jul 22, 2013 03:32 PM
Uncle Ben's
Jan 20, 2008 08:22 AM
