Drum-to-disc swap... ABS?
Old Dec 15, 2005 | 04:35 AM
Ax3l's Avatar
Default Drum-to-disc swap... ABS?
When swapping rear abs drums over to disc setup (from a abs car), can i just splice the cut ABS sensor wires (connected to the sensors on the disc setup) onto the cut sensor wires on my car and the ABS system would work fine?
Or is there som kind of trick for making rear disc conversions work with ABS?
-Thanks.
Old Dec 15, 2005 | 05:45 AM
Boilermaker1's Avatar
Don't cut anything. Take the sensor out of the drum WHOLE, pull the sensor out of the disc and plug the sensor from the drum in.
Old Dec 15, 2005 | 08:05 AM
blouisgod's Avatar
Default Re: (Boilermaker1)
yeah, no need to swap the wheel sensors. just pull the stocks out of the back of the drum with a flat head screwdriver and put them into the si hubs.
Old Dec 15, 2005 | 10:01 PM
Ax3l's Avatar
Ah thanks alot.
The sensors on my disc swap was cut... glad i did not have to use them then.
Anyone else confirm that drum sensors works on disc setup?
Old Dec 16, 2005 | 04:18 AM
How much more confirmation do you need?
We're telling you that it works.
Old Dec 16, 2005 | 04:39 AM
Ax3l's Avatar
Hehe, it's cool.
Just heard something about using the sensors from the disc setup. But ill just do it the easy way, like stated here.
Old Dec 16, 2005 | 06:44 AM
Well then I can tell you that when I plugged in the sensors from the discs it threw the ABS light on. When I plugged the drum sensors into the disc, the light doesn't come on.
Old Dec 18, 2005 | 10:51 PM
Ax3l's Avatar
Sweet, thanks.
Just thought it would be harder to fix ABS disc swap than this.
ShadowsEGSedan
Suspension & Brakes
Feb 8, 2013 07:16 AM
c1_sleeper
Suspension & Brakes
Oct 16, 2008 07:10 PM
mmp1214
Aug 7, 2008 01:21 PM
RA122324
Aug 28, 2006 02:45 PM
