new swap, wont turn over :(
Old Dec 14, 2005 | 11:11 PM
jake1511's Avatar
Default new swap, wont turn over :(
im stumped. i just installed my swap from hmotors not too long ago and i tried to crank it with a BRAND new battery and the starter wont turn over. i hooked the ignition wiring up right, ive tested the starter, and ive tested the battery, i have everything hooked up right at first i grounded the battery to my frame and then my friend told me to try grounding it to the transmission and i put it on the bracket that holds the clutch cable in place that's mounted on the transmission, no luck. any suggestions?
Old Dec 14, 2005 | 11:14 PM
Blue Hybrid's Avatar
Default Re: new swap, wont turn over :( (jake1511)
try the starter out of the car, be careful it will jump a little
just ground the negative anywhere on the starter motor casing, and put power to the input
Old Dec 15, 2005 | 04:57 AM
badboyr66's Avatar
Default Re: new swap, wont turn over :( (gold EF)
or just check voltage at the starter while a freind attempts to turn it over. Most likely something small and overlooked
SiRCiviC94
Sep 1, 2013 07:05 PM
jdmcivic2fast
Sep 15, 2012 04:59 PM
dj-t
12
Dec 5, 2011 06:18 PM
Jonathan_ED3
Aug 14, 2008 06:15 PM
go2sleep
May 6, 2007 08:42 PM
